Jun-22-2020 09:06 AM
Jul-15-2020 09:53 AM
Brettmm92 wrote:
Thanks for all the information!
I definitely plan to get a battery, more so now since the emergency brake function is pretty important.
Another thing that I wish I put in the original question is that I'm aware an inverter is needed to convert the dc power from the panels to ac. Do the travel trailer wires that connect to the battery have their own inverter or something? And where would I install that? I'd imagine that I'd have to fiddle with the wiring inside as leaving an inverter outside sounds like a bad idea to me
Jul-14-2020 11:34 AM
Jul-14-2020 11:23 AM
Jun-23-2020 02:55 PM
Jun-22-2020 01:12 PM
Brettmm92 wrote:Inverter can be a bit complex depending on size. Less than 300 watts can be installed easy behind the breaker panel, use the main 12v connection for power, and connect to the panel with a transfer switch.
Jun-22-2020 01:02 PM
Jun-22-2020 11:32 AM
Jun-22-2020 10:43 AM
Brettmm92 wrote:This statement indicates you're thinking of panels as devices that 'run things.' They don't, they charge batteries, then it's the power from the batteries through the inverter that runs things. Ok, picky picky, but it's really how it works. An analogy is you don't take your paycheck to the grocery store for a loaf of bread, you deposit it in your bank first, then draw from that.
Jun-22-2020 10:42 AM
Jun-22-2020 10:25 AM
Jun-22-2020 10:24 AM
Jun-22-2020 10:13 AM
Jun-22-2020 09:53 AM
Jun-22-2020 09:52 AM
