โJul-10-2016 05:03 PM
โAug-11-2016 01:50 PM
โAug-11-2016 10:51 AM
โAug-11-2016 09:07 AM
โAug-11-2016 07:42 AM
Vinsil wrote:wuli959 wrote:SoCalDesertRider wrote:
Increasing the air bag pressure and lifting the truck off the overloads will increase sway, not decrease it. You need to decrease the air bag pressure and keep the truck firmly planted on the overloads. If it's too low in the back at that point, add another leaf to the overloads.
I first drove it with minimum air in the airlift bags; on the overload springs and I don't think that I was too low in the back but had a lot more sway side to side then where I started. (has a bigwig sway bar)
I'm still on the overload springs with 30 psi in the bags but not sure how much pressure is on them. I guess better but not what I was hoping for.
Its my first truck camper and maybe I just need to get used to the "sway".
Or add another spring to the back. :@
Only you know how much sway is comfortable. You may also be experiencing tire squish...are you at full pressure on your rear tires? What brand and weight rating? I know my biggest help with sway after my stableloads...was my tires.
โAug-08-2016 01:07 PM
โAug-08-2016 01:05 PM
โAug-04-2016 01:59 PM
You can make this contact happen if you use airbags to raise the rear by extending your bump stops. I use Energy Suspension ones. There are other options as well.
โAug-04-2016 01:52 PM
โAug-04-2016 01:47 PM
โAug-04-2016 08:08 AM
Powerdude wrote:
4 inch drop in the back is not bad. It's obviously not perfectly level, but it's not bad.
Is it pointing up in the front at all? Any drop in the front?
โAug-04-2016 07:46 AM
Vinsil wrote:
Yup. if your pretty level and it feels good (better) stick with it. You can play with your bag pressure some to dial it in.
โAug-03-2016 06:55 PM
sonuvabug wrote:whizbang wrote:
... snipped ... You have the wrong Bilstein shocks. The 5100 are their off road shock. The 4600's are the heavy load shocks.
I respectfully disagree. The 4600 and 5100 series have the same internal working bits. 4600's are for stock height ... the 5100's are for lifted suspensions starting with the 0-2" lift range.
This explains the differences:
http://www.shockwarehouse.com/news/images/bilstein-5100-vs-bilstein-heavy-duty.cfm
The OP did not mention a lift to his truck set-up. Therefore, either shock will work just fine and no need to replace them if they are in good working order.
โAug-03-2016 05:57 PM
โAug-03-2016 05:08 PM
