Rear leafs have less spring on one side
RKW
My passenger's side leaf springs are allowing the truck bed to sag about an inch lower than the driver's side. Nothing appears to be worn or broke. The passenger spring pack seems to just be more "tired" than the driver side. Is an inch difference tolerable? I was talking to a guy who works in a suspension shop and he said when they take corner to corner measurements it's not unusual to see that much of a difference. Thoughts?
Thanks.
Ryan
  • 2015 Ford F250
  • 2015 Rockwood Signature Ultralite 8280 WS
  • Dual Honda EU2000i Generators
    The wages of sin are death; but after they're done taking out taxes, it's just a tired feeling.
10 REPLIES 10
RKW
RedRocket204 wrote:
stickdog wrote:
I worked with a guy that weighed 350+ his driver side sagged.
Sooo, you're saying the OP needs to put on a bunch of weight and then his truck will ride level, side to side? 😄
This is a rough crowd! 🙂
Ryan
  • 2015 Ford F250
RedRocket204
I love me some land yachting
Rockrash
How old is the truck? The passenger side is the torque wheel. When you accelerate that wheel in effect is pushing up on the suspension. By theory this can weaken the passenger side spring over time.
Or maybe your passenger needs to lose a few pounds.
stickdog
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
RKW
christopherglenn wrote:
If you have torsion bars up front, adjust them to make the front level side to side with a floor jack under the rear axle (to keep the rear tires off the ground). Then lower it and recheck the rear end. If you can't help it with the tbars, it gets expensive.
Are you saying that if the front torsion bars are in need of adjustment it can unevenly squat the rear?
Ryan
  • 2015 Ford F250
tvman44
You can have the springs re-arched. 🙂
Papa Bob
Husky 16K hitch, Tekonsha P3,
christopherglen
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
RKW
ib516 wrote:
I'm thinking if you check close you will have one leaf broken on the side that's lower.
Just spent the last 1/2 hour crawling around under my truck with a flashlight and a mirror. . I can't see anything broken or worn.
Ryan
  • 2015 Ford F250
Old-Biscuit
" Is an inch difference tolerable?"
To me it wouldn't be!
I would have both rear set of springs removed/inspected/repaired as needed and re-arched.
Surprised suspension shop guy didn't recommend it.
ib516
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
