โJul-11-2017 03:18 AM
โJul-11-2017 04:59 PM
โJul-11-2017 02:36 PM
โJul-11-2017 02:15 PM
โJul-11-2017 01:05 PM
ktmrfs wrote:sch911 wrote:
The capacity stickers are inside the front door jamb. Yes they are there it's the law.
GVWR - Actual weight of the truck loaded = Payload.
In this case loaded means the pin weight of the 5er is included.
GCWR - Actual weight of the truck loaded = Tow Capacity
Note: The stickers ratings can be off if your trucks options vary from the base model.
You can safely tow right up to these levels. Your truck has been certified at those levels for safe towing by GM engineers. There is no need for any extra safety margin.
a correction. the sticker in the door is for that specific vehicle. It accounts for ALL the options installed at the factory. It won't account for dealer installed options.
โJul-11-2017 12:35 PM
โJul-11-2017 12:01 PM
โJul-11-2017 11:46 AM
โJul-11-2017 11:04 AM
โJul-11-2017 10:56 AM
โJul-11-2017 10:48 AM
โJul-11-2017 09:19 AM
โJul-11-2017 08:54 AM
Unitech123 wrote:If your 2016 has no stickers you should sue the manufacturer and the dealer cause you just hit the jackpot (unless you bought it used and that guy removed them).
Thank you all for your assistance. Although there are no stickers on the truck (my 2010 has them, my 2016 does not) I am comfortable with the 13000 and with the thought the 3/4 isn't quite up to the Montana. When I am ready to quit work and don't need my trucks to serve two masters I'm sure we'll upgrade to a one ton but until then we'll find a better 5th wheel fit. Thanks again.
โJul-11-2017 08:12 AM
โJul-11-2017 07:45 AM
Unitech123 wrote:
The truck is new. There are no stickers on either door. I have the sheet from the window and it has nothing useful. I googled the truck and got a GVWR of 9500, max trailer of 13000, and weight distr max tongue weight of 1300. There are just 2 of us (and sometimes a dog...) and we very rarely if ever carry water in our tanks. I am specifically looking at a used Montana 3150 because it has a king-sized bed and their web site shows a shipping weight of 11134 and a carrying capacity of 2831. So does that assume a max weight of 13965?
