scorched my door with a torch, any way to fix?
hedge
I had the camper out for the holidays and decided to wash it before I put it back into storage. It's cold up here and I guess I managed to get water in the locks and it froze.
I was using a small lighter to try melt out the ice but go impatient and did something really stupid and decided to speed up the process with a hand held plumbing torch.
Well I managed to scorch the door of my hard side (Filon?) above the door handle.
Is there any way to fix it or do I just have to resort to covering it with a sticker?
2017 F350 Platinum DRW
2013 Adventurer 89RB
10 REPLIES 10
54suds
decal
2021 Chev 6.6 duramax ltz DBL cab,drw,4x/torklift tdn's,
1999 Bigfoot 1011
joelc
Next time use a hair dryer. Hast makes waste. But we have all done stupid things.
kohldad
Instead try some car polishing compound. You may luck up with being able to just rub it out. Just remember you can try the non abrasive stuff first then go to the sand paper later but not the other way.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
hedge
thanks for the tips, I'll probably try sanding and painting it and then resort to a sticker if that doesn't work. No bubbling, just discoloring.
sch911
Best way to unstuck a frozen lock is with hot water. Then use WD40 to dislodge the water from the tumblers. And follow up a with graphite based lock lubricant.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
Old-Biscuit
Others have given you tips/suggestions
Hard to say what will work w/o seeing how much damage was done.
Next time door lock freezes........heat the KEY not the lock
azrving
Dont ya hate that. I got to end of some interior trim work and removed a piece of tape and removed the cheap woodgrain veneer off the slide trim. Smack dab in your face area.
Some type of trim as you mentioned. Something durable like thin stainless. Like a surround trim cut to fit around the handle/lock assembly.
Or tape evenly around it and paint it black or maybe a color that is elsewhere on the rig.
path1
Pick up one of these at Lowes or Home depot. If you want to get fancy swing by a trophy sales place and engraver and on some design put on. Drill hole for lock and slap on.
https://www.google.com/search?q=bottom+door+plate&biw=1188&bih=566&source=lnms&tbm=isch&sa=X&sqi=2&v...
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
Kayteg1
Picture?
If you don't have blisters, cheap spray can from HD should do decent cover up.
TucsonJim
Can you paint it?
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
