side step hight
bbaker2001
new 3500 ram 4x4
it is high off ground. need side steps. have look at other posts, but cant tell if any are lower to the ground. are any made that have longer bracket to lower them. Ram is higher than Chevy and Ford.
really don't care for the auto ones.
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
10 REPLIES 10
john_bet
I put running boards on our 2wd right after getting it. We went to a local accessory store and ordered them. I installed them. For the '11 Jeep I ordered running boards from running boards.com. They were a perfect match and complete instructions included. They were easy to install.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
Me_Again
We have the OEM side steps and they work fine. Truck is tall!!! Chris
transamz9
These are the bars on my 13. They are from Ram. They are great and I couldn't imagine trying to get in without them.
These are the ones I put on my 2005.
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
csamayfield55x
When I got my Ram in 08 my wife threw a fit about getting in and out. Next day I ordered a set of tube steps from JC whitney for less than 300.00 and they have been great since. Just enough to use to get in but not enough to drag when off roading
Chris
2008 Dodge Ram 3500 6.7L Cummins Quad cab
B&W 20K turnover ball, Proline custom flatbed
Tekonsha P3
2015 Open Rang Light 311FLR
1oldtruck
AMP Research Power Steps are great. They are adjustable and drop down further than the factory step rails. They also retract out of sight when the door is closed. They are a bit expensive compared to factory steps.
Calicajun
We have Amp steps/running boards on our 2500 4x4 Ram truck. They work well for us as they come down a little further and out from the truck a little further also. Wife says they make it easier to get in and out of the 2500 than it was the 1500 Ram 4x4 we use to have with factory running boards.
2014 Heartland Wildness 2775RB, 2015 Ram 2500 4x4 Mega Cab
BenK
check out this thread:
New Silverado 2500 HD - Truck May Be Too High for Wife
runningboards backout
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
rhagfo
bbaker2001 wrote:
hello Russ, you seem to be our go to guy for info.
are these the stock ones from dealer.
and if I order online are all steps going to be same height?
we drive to Idaho Monday to get truck. am so excited
Mine are not steps, but wheel well to wheel well running boards. I like as the surface doesn't get muddy, and they keep the sides of the truck clean.
This is the best picture I have of them.
bbaker2001
BB from California
2015 Ram 3500
2001 Cardinal
rhagfo
bbaker2001 wrote:
new 3500 ram 4x4
This was the first request from the DW when we bought our Ram, I ended up putting full length running boards on. Best thing I did to the truck, we both have easy step into cab, and I use the back part to access the bed and tool box.
