Sep-28-2015 03:53 AM
Sep-30-2015 04:58 AM
rjstractor wrote:06Fargo wrote:
How many quarts of gas per how many quarts of oil, expressed in 2 cycle ratio.. 200:1?
I'd guess about 240:1- 2 tank of gas per quart= about 60 gallons per quart= 240:1. But if it smokes only on startup the ratio is not constant.
Sep-30-2015 02:32 AM
Sep-29-2015 11:49 PM
Anmacc2 wrote:
My van is burning oil because of rings. It is slowly getting worse. I am now burning 1qt per two tanks of gas. It is too big a job and too expensive and not worth it to me to fix it at this point. What will happen as the issue progresses? Will I just burn more and more oil? I only put maybe 9,000 miles a year on it.
Please stay to the topic and answer the specific question to help me. 🙂
I sincerely appreciate the generosity and caring of this site!!!
It only smokes when I first start it. After just a minute or two it stops. No residue on the fender or exhaust. Does that she'd more light?
I have one plug that fouls. Drivers side, third one back. I change it every 10-15 thousand miles when I develop a miss. Check engine light comes on occasionally. I put injector cleaner in the gas and run it down the hwy at 75mph for a hundred miles and it goes off at some point. Planning a 6000 mile road trip in the spring and hoping to nurse it through a couple more years.
Sep-29-2015 08:43 AM
Sep-28-2015 07:04 PM
Sep-28-2015 05:12 PM
Sep-28-2015 02:41 PM
Anmacc2 wrote:pitch wrote:
Once you start smoking bad enough,,,,,
Sep-28-2015 02:25 PM
Sep-28-2015 11:46 AM
Sep-28-2015 10:00 AM
Sep-28-2015 09:23 AM
Sep-28-2015 07:49 AM
Sep-28-2015 06:11 AM
Sep-28-2015 05:53 AM
