ST trailer tire 75 mph rated
rexlion
For those who prefer to tow a little faster than 65 mph, as well as for those who would like some extra cushion in their tires' speed rating, I recently learned that Hercules ST tires are rated for 75 mph. Just wanted to let folks know about this additional option. I am getting one put on my cargo trailer next week (they had to order it from the warehouse, the store didn't stock it).
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
132 REPLIES 132
mrw8i
58mph for me. I feel good like I'm making up time. My mileage is much better at 58 as compared to 65. I'm going slow enough so that when you pass me doing 65 or 75 pulling that trailer swaying behind you; you are passing me quickly and I don't have worry as much about that trailer you are pulling swaying across the lines and almost hitting me.
And yeah ST tires - have you ever picked up an unmounted one. Feel that "thickness-less" of the sidewall. Notice the lack of deep tread. I run "D" range ST tires on my 6,000 GVWR trailer, I run LT on my 14,400 GVWR (dual 6,000lb axles, the rest is on the pin) 5th wheel.
CKNSLS
Love your post Timeking. I'm right there with you. I have seen rigs fly past me in a 100 degree heat and then up the road they have a blowout.
Timeking
If you've ever been behind me, you probably hate my guts, because I get 'er up to a roaring 56 mph and hit the cruise button. Sure I see you guys go flying by me, sometimes giving me the finger, but I've also seen fiberglass and aluminum siding splattered all over the side of the road. As far as LT/ST question, everytime I've needed tires I've been in Nowhereatall Nearnothing. I go to a tirestore and have them put on what they've got. My tires never rot because I wear the tread off them first.
westend
edwardt48 wrote:
I need 205/75r 14 tires and st is all that is avaible and I think all st tires are made in China
Not all but close. I had the same situation, had to have ST replacements. I bought these Carlisle Radial Trail RH in Load Range D. I think most folks are having good luck with them and they are sold nationwide at Discount Tire.
'03 F-250 4x4 CC
Xflyhighx
Maybe jimnlyn should figure before running his lips. I run an average of 3 to 500 miles a day. If you can't don't mean I can't. And further more I change tires every 3 to 4 years depending on miles and tread. I'm sorry to the other members to have to read what other members can't figure and they don't have anything of merit on a topic.
2019 Cedar Creek Champagne 38EL
TrailAir Pin Box
Hensley TS3 trailer saver
2017 Laramie Longhorn 4x4 dually
14' Porta-bote
Honda 3000is or 2 Honda 2000โ€™s
Life is good in the good old USA
CALandLIN
Here are a couple of super popular Michelin tires. Both are LT235/85R16E rated at 3042# maximum load capacity and thatโ€™s just about where the similarity ends.
XPS RIB Tread Depth 15/32โ€
Weight 56#
Overall Diameter 32โ€
Rim Width Range 6-7โ€
LTX M/S2 Tread Depth 13.5/32โ€
Weight 43#
Overall Diameter 31.7โ€
Rim Width Range 6-7.5โ€
A tireโ€™s carcass provides itโ€™s maximum load capacity (of course you must have air pressure). Everything else is added for lasting performance and durability. The XPS Rib has an extra steel belt. It has an all steel construction, taller treads, retreadability, and sidewall inserts for protection against curb scrubbing. Itโ€™s one tough tire, designed primarily for inner city pick-up and delivery.
Durability does not add strength to a tire.
JIMNLIN
Xflyhighx wrote:
Well...we are about 3500 miles into our trip with the new Hurcules tires. Been running on the highway at 70-75 and about 8500 lb loaded. The tires look like I just put them on and there is no signs of ware. So far I am very , very happy with them.
3500 Miles in 3 weeks ??
Come back when you get 5-7 years and/or 45k-55k miles on those tires and give us a report.
edwardt48
Xflyhighx
TrailAir Pin Box
14' Porta-bote
westend
SprinklerMan wrote:
Steve B. wrote:
This is year 2 of running the Kumho tires and so far so good. I got them from Tire Rack, advertised as an ST tire. When they arrived they were marked as LT. I inquired about that and TR assured me they were manufactured for trailers. Whatever. They have the higher speed rating so I don't worry about running at 65. I've only pushed 70 when passing a kidney stone and I had to get somewhere for help fast. That's another camping story to forget...
How fast was the kidney stone going ?
Not fast enough...
Man, I hope you haven't jinxed yourself to having a kidney stone and having to endure the pain. :E
I can still recall the feelings I had passing the first one. The pain was so intense that when we reached the hospital, I bypassed the check-in procedure, went through the ER doors, and flopped on an exam bed. I seem to recall having my wallet in hand with health insurance card, credit cards, and cash. I alerted staff that everything was in order and I had the wherewithal to pay so just "knock me the f*&^ out". They eventually did.
I can't imagine driving myself to the ER. The Bronco I was in at the time must still have the grip marks in the dashboard.
'03 F-250 4x4 CC
SprinklerMan
rbpru
I B done also.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
Camper_G
I have Hercules 15" load range D radial tires on my 6k lb Layton for the past 2 going on 3 yrs. No issues at all.
I do keep them covered, run 60mph on the highway, air them to max sidewall pressure (65psi) before going in a trip and I'm very careful not to curb them and fortunately have not done so. I got the radials over bias ply. Better construction in my opinion. Just my .02.
2017 Dodge Ram 2500 HD, 4x4, CCSB, 6.4L HEMI, Snow Chief, tow package.,1989 Skyline Layton model 75-2251.
Steve_B_
2000 Twister by Fifties Trailers,
2017 Honda Ridgeline
2003 Miniature Schnauzer, Meyer
