Starting batteries instead of deep cycle
burningman
So Iโ€™ve got a theory...
Deep cycle batteries are designed to slowly discharge low current for a long time.
Starting batteries are designed to put out high current for short periods.
Generally, people use deep cycle batteries in their RV.
Well, the main work my batteries do is power a 2000 watt pure sine wave inverter and run my Keurig K-cup coffeemaker and microwave. Those are short duration, high current loads.
It kinda seems like maybe a set of regular starting batteries might actually be better.
Any opinions from the panel?
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
36 REPLIES 36
otrfun
We easily power a 1100 watt (line input, not cooking power) microwave with our two Costco 6-volt GC2 batteries (110 amps DC). Briefly powered a 1250 watt coffeemaker with no issue, but generally we use a smaller k-cup coffeemaker that only draws 750 watts.
If I was having similar problems as the OP I'd be checking voltage at the battery and inverter terminals under maximum load. With the batteries fully charged, the voltage at the battery terminals shouldn't drop much below 11.8 volts or so with a 100-120 amp load (with two GC2 batteries). Ideally, Iโ€™d strive for no more than a 2% (.24v) voltage drop between the battery and inverter terminals with a maximum load. Any irregular voltage readings might be indicative of a bad battery, too small battery/inverter cables, or bad connection/ground.
burningman
ajriding wrote:
burningman wrote:
ajriding wrote:
No, just no to the OP.
Starting a motor is WAY more draw than any inverter you would be using. Your inverter is still only requiring a slow discharge from the battery. I'll stop here
I got the much-touted two-six-volt Trojans. Now my inverter wonโ€™t run my coffeemaker.
I had two 12-volt Costco marine/RV batteries. I always just used regular starting batteries before that. The screwy thing is, they would run it.
These real deep cycle Trojans just canโ€™t put out enough current at once.
I'd have to do more research. My first thought is not that the batteries were not up to snuff, but maybe the wiring or something else is happening on this one incident. If you are pulling so many amps that a marine battery cannot keep up then I suspect that you are demanding more than 1000-1500 watts of a coffee maker or that there are other issues preventing a free flow of amps to the always inefficient inverter.
I have started cars with one marine battery and I do not suspect that a coffee maker on an inverter requires more amps than a starter motor.
This rigidness of resisting the camping lifestyle when camping seems to be costing RVers a lot of money (in this case for batteries they really do not need). Getting in an RV mindset means using RV-friendly coffee makers, which probably will run on propane, not electricity. Many things RV are designed to be efficient on what the RV offers. Those that want the exactness of house living usually buy brand new class-A motorhomes with huge generators they plan to run all the time.
I would ditch the idea of creating enough power to run a house and get on board with the camper life.
I have 2-0 โ€œdouble-oughtโ€ cables that are about two feet long. That sure isnโ€™t the problem.
Iโ€™m talking about electricity and making some gear I own work the way I want it to.
Not whether you think I โ€œshouldโ€ have my electric coffeemaker.
I can throw a few batteries in and still be WAY below what lots of guys are spending on new F450s and new Rams to carry their camper on.
This setup worked on regular old batteries. Thatโ€™s probably what I should go back to.
jaycocreek
I understand what starting batteries are for and how theyโ€™re made.
I also see what the 6-volt deep cycles canโ€™t do that my old conventional batteries couid do. So whatโ€™s a guy to do?
If it ain't broke,don't fix it..
The internet is ruining RVing,making it way more expensive than it has to be...So many things work and have worked for years but there all but black listed on the net and anyone that does it that way is a neanderthal..Laffin
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
zcookiemonstar
Kayteg1 wrote:
zcookiemonstar wrote:
... This system was designed with AGM deep cycles not starting batteries. If starting batteries were a better option I think they would have use them here.
AGM batteries are another sample how customer can be fooled by sales pitch overwhelming common sense.
The only advantage of AGM batteries in any application is that they can work upside down, or lay on its side + they have higher charge ratings.
Sadly they don't last long.
In older Mercedes cars we had flooded battery lasting 13 years, when in newer models AGM batteries seldom last longer than 4 years.
You can still buy flooded starting batteries with 96 months warranty, when the best warranty on AGM is about 1/2 of that.
No the reason for the AGM in this case is because they are in a house and do not off gas like a flooded battery so less need for venting to the outdoors.
Point was not for the AGM but the deep cycle battery.
pianotuna
Nomad III
Nomad III
burningman,
The answer is in the cell count. A pair of marine 12 volts have 24 cells. A pair of six volts only have 12 cells. So the demand per cell is twice as high.
Many batteries are rated at 25 amps per cell.
Regards, Don
ajriding
burningman
Two thousand dollars for a pair of lithiumโ€™s isnโ€™t happening. I donโ€™t use this camper enough to justify what it already cost, much less adding that. Thatโ€™s 142% out of the question.
ajriding
Kayteg1
zcookiemonstar
Not sure how much it relates but I have a battery back up sump pump system. My system uses a 1/2hp A/C pump. The system uses two 12 volt 100 ah agm deep cycles and a 24 volt dc to 120 volt A/C inverter. The system is designed to run several hours during power outages. Sump pumps are high inrush shorts runs over and over. This system was designed with AGM deep cycles not starting batteries. If starting batteries were a better option I think they would have use them here.
work2much
jimh425 wrote:
Kayteg1 wrote:
Naaahhh... none of US coffee shops serves 1l coffee.
I think all coffee shops will sell you a liter if thatโ€™s what you want.
We routinely have gas stations, coffee shops, diners and cafes fill our 1 liter Stanley thermos.Sometimes they have to ask a manager what to charge but never denied.
As far as using battery/inverter to make coffee we have a single cup Keurig. It only runs the heating element for 2 minutes for each cup.. That uses 2 amps per cup. Pretty manageable even if you make 2-3 cups every morning.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
Kayteg1
If you find 1l cups in any coffee shop, please post the pictures.
The biggest I am finding are 1/2l.
Than took me special search to find big cup that fits under cappuccino machine.
Will have to take my own picture as even google don't have them
jimh406
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
Kayteg1
SidecarFlip wrote:
mi.drew wrote:
I find that the easiest thing on my batteries is to use a French press coffee maker.
Amy and I prefer perked coffee in a Cabelas coffee pot.;)
No battery drain at all..lol
