May-10-2015 07:56 AM
May-13-2015 12:04 AM
bowebow wrote:
How often has a problem been found with campground or trailer electric?
May-13-2015 12:00 AM
SoundGuy wrote:ROBERTSUNRUS wrote:
Hi, I have two polarity testers; One is always plugged into an inlet in our trailer's kitchen and the other one is connected to a 30 amp RV adapter, mounted in a piece of black plastic pipe, (so you can see it better) and used at the power source before connecting my shore power cord.
Bob:
I'm wondering what value there is in leaving a polarity checker always plugged in inside the camper :h ... after all, once the campsite source supply has been verified as being correct it's not suddenly going to change. If you'd want to monitor anything it would be the incoming source voltage which can change during the course of your stay.
May-12-2015 11:51 AM
May-12-2015 10:42 AM
May-11-2015 09:52 PM
rockhillmanor wrote:
Before I plug in this goes into the shore station.
After I plug in this goes into an outlet inside the RV.
Let's you know what is going on at the shore station and when plugged inside it tells you when something does happen later.
May-11-2015 01:05 PM
samhain7 wrote:
I'm an idiot.
Checked my adapter and it he ground is broken off
May-11-2015 12:41 PM
downtheroad wrote:
I am assuming that you are plugged into shore power..
Sounds like you have a faulty ground. Check the ground wire to the frame. Mine is near the steps to the door on the frame. It might be corroded, loose or missing.
May-11-2015 10:49 AM
May-11-2015 07:50 AM
May-11-2015 07:07 AM
samhain7 wrote:
So how can I check if the problem is really fixed? Multi meter?
May-11-2015 06:54 AM
May-11-2015 06:05 AM
May-10-2015 04:18 PM
May-10-2015 12:32 PM
