โApr-13-2017 06:09 AM
โApr-14-2017 04:31 PM
ksu_j wrote:
Still interested in hearing from anyone about better shocks for a truck like this one also.
Thanks!
โApr-14-2017 01:37 PM
โApr-14-2017 12:51 PM
โApr-14-2017 12:07 PM
โApr-13-2017 12:44 PM
โApr-13-2017 11:54 AM
STEVEO496 wrote:
Is the vibration still there if the vehicles is coasting in gear and/or in neutral? Does the vibration get worse when the rear wheels are under power?
โApr-13-2017 10:20 AM
โApr-13-2017 10:09 AM
ScottG wrote:This happened on my Chevy Blazer, mechanic said it looked fine, took it apart and had a dry u-joint. Wasn't loose but would bind driving down the highway and give a vibration.
I would check U-joints at this point. That means pulling the drive shafts and actually manipulating the joints.
You can have a dry, tight joint that wont show up just reaching up and trying to move it by hand. I chased a vibration caused by one of these for several years!
Shocks dont cause vibrations.
โApr-13-2017 10:05 AM
โApr-13-2017 09:58 AM
STEVEO496 wrote:
Check the carrier bearing on the rear driveshaft if equipped.
โApr-13-2017 09:45 AM
โApr-13-2017 08:48 AM
โApr-13-2017 08:43 AM
