โJun-21-2017 11:39 AM
โJun-23-2017 08:15 AM
โJun-23-2017 07:34 AM
spoon059 wrote:
By the way, just one more example to prove that they are arbitrary... I live in Maryland. Maryland allows me to register any vehicle for any weight that I want, I just have to pay a higher tax/registration fee for that higher weight. I can register a Ford Ranger for 12,000 lbs GVWR if I want to. If I put E rated tires and wheels with a load capacity of at least 3000 lbs on my Ranger, I can legally load that Ranger down to 16K lbs. I can then figure out a way to load a heavy 5th wheel on that Ranger and drive it through California on my regular non-commercial class A license which rates me to drive any non commercial vehicle and any non commercial trailer.
While incredibly stupid to do so, California couldn't do a darn thing about it. I'm under the federal bridge limits of 20K per axle, I'm under my registered weight of 12K lbs and I'm under my tire rate of 12K lbs. This is all hyperbole, mind you, because the Ranger likely wouldn't make it out of my driveway without falling apart, but my point is that it would be PERFECTLY LEGAL.
โJun-23-2017 07:23 AM
spoon059 wrote:
. . . Axle ratings and GVWR are simply a warranty number imposed by the manufacturer. There is no way for law enforcement to enforce those arbitrary numbers.
otrfun wrote:
TX and CA (and other states) use the GVWR and/or GCWR of various RV's (motorhomes, TV's and trailers) to determine whether a state issued Class A/B/C (non-DOT) license is necessary. It would seem, at least in some states, the DMV and law enforcement view GVWR/GCWR as a bit more than arbitrary and/or a "warranty number".
spoon059 wrote:You choose to see the state laws pertaining to GVWR/GCWR as arbitrary, unenforceable, generally ineffective, and the manufacturers GVWR for warranty purposes only.
Now you understand exactly WHY manufacturers offer a 3/4 ton truck, as opposed to a 1 ton truck. They do it because of arbitrary numbers like California and Texas deciding that a truck OVER 10,000 lbs is commercial, whereas a truck at or below 10,000 lbs is not commercial. There is very little mechanical difference between the two vehicles (assuming SRW only)... but one is arbitrarily given a 10,000 max GVWR simply to comply with the weight designation of certain states.
You are proving my point. All these numbers just mean a different level of tax from each state. These states require a more expensive registration fee, or a more expensive license for trucks over being over 10,000 lbs. It doesn't make the one vehicle more or less capable than the other... it just allows the state to collect more money for allowing you the privilege to drive it.
โJun-23-2017 04:39 AM
โJun-22-2017 09:00 PM
ShinerBock wrote:
Riddle me this.... What is the difference mechanically between an F250 with the camper package and a regular F350? Or between a regular F350 and one with the 10k GVWR package?
โJun-22-2017 08:51 PM
โJun-22-2017 08:33 PM
spoon059 wrote:TX and CA (and other states) use the GVWR and/or GCWR of various RV's (motorhomes, TV's and trailers) to determine whether a state issued Class A/B/C (non-DOT) license is necessary. It would seem, at least in some states, the DMV and law enforcement view GVWR/GCWR as a bit more than arbitrary and/or a "warranty number".
โJun-22-2017 02:52 PM
Txsurfer wrote:
SO if I get scaled by DOT what will they go by? Axle ratings?
โJun-22-2017 02:32 PM
blt2ski wrote:
I'm also waiting for someone to.show me in both federal and state laws etc, where I have to follow the numbers on my door sticker.
Marty
โJun-22-2017 02:28 PM
โJun-22-2017 02:20 PM
โJun-22-2017 12:52 PM
โJun-22-2017 08:54 AM
ShinerBock wrote:tinner12002 wrote:ShinerBock wrote:
What modern 3/4 tons are rated to handle and what it can actually handle are two very different numbers.
Also, please post the law requiring you to stay within the manufacturers tire load and inflation sticker. I have asked this many times and not one person has ever been able to provide it. The only laws I know of about what a vehicle can legally haul or tow is in regards to the registered GVWR(which can differ from the trucks actual GVWR) and GAWR limits.
If you do not have much knowledge about tow vehicles or towing in general then I recommend staying within whatever the manufacturer suggest. If you have plenty of knowledge and experience to know what a vehicle can safely handle, then by this point you would have already known that a 3/4 ton can handle way more than what its (de)rated for.
I totally disagree with the last statement!! Trucks I'm sure are capable of more than they are rated for but they have those ratings for a reason, frame, tranny, axle, bearings, wheels and tires, u-joints are all designed to withstand just so much weight. When they use these ratings all those items and more are taken into consideration. There is a certain amount of safety margin built in I'm sure. Some people exceed the safety margin just because the truck pulls it just fine...not very smart in my opinion. Obviously some think they know more about weights and measures and frame stress and parts durability than the manufacturers and those are again in my opinion the dangerous ones on our hiways!!
With that said, the OPs generalization of what trucks tow what is a pretty good summary.
Nope, that is not the case. Today's 3/4 tons have the same frame, brakes, axles, front suspension, bearings, and so forth as the 1 ton SRW. They are basically identical trucks aside from the rear suspension. In fact, with certain makes, you can add a package to a 3/4 ton and make identical, rear suspension and all, to the 1 ton variant.
Case in point is Fords camper package for the F250. Pay the $170 for the package and you have an F350 with an F250 badge on it. Ford also has a package for the F350 that will de-rate it down to the specs of an F250 on paper so that it will cost less to register for fleets. It is called the 10,000 GVWR package.
In the old days, what you say was true. There were many distinct differences between a 3/4 ton and 1 ton that effected the rated capacities of each. That is not the case anymore. They are basically identical aside from there rear suspension and the 3/4 tons are neutered on paper due to the governments 10,000 lb max GVWR of the Class 2B truck class they are in.
โJun-22-2017 07:54 AM
โJun-22-2017 06:55 AM
