โFeb-14-2017 08:51 PM
โFeb-17-2017 04:04 AM
blt2ski wrote:
Actually, in Wa st, EVEN if pulling for personal pleasure, one must stay under the FBL's, have a high enough paid for license. Follow the truck speed limit of 60 mph even if it is legal to 70 for cars, assuming over 10K in any way shape or form. Need to chain up when signs say to do so over 10K. This will also include those under 10K, but paid for license is over 10K, or the max sum of truck and trailer can be over 10K........You do not need to go to scales, make up a log book etc. BUT, from a weight perspective and a few other things, yes one must follow the same rules regs etc.
marty
โFeb-16-2017 09:06 PM
blt2ski wrote:deltabravo wrote:blt2ski wrote:
Anything in Washington st over 10k, be it gvw or gcw has to.follow truck speed limit max of 60 mph anywhere! Chains required over 10k where appropriate, whether you have a 4wd vehicle pulling trailer, or single dually 4we rig. Based on PAID for licenses,
Just because you are an RV per say, does not mean you can get away with out following some of the.commercial style rules.
Marty
I did not know that.
I'm not questioning the validity of your statement, just curious where I can ready that info - what's the RCW that makes the statement about following the posted "truck" speed limit when the vehicle is over 10k?
I do not know the rcw off the top of my head, BUT talking to many cveo, leo's from the SP, they have ALL told me this is true from the over 10K total. Most of what I have learned is from a couple of classes taught by CVEO's.
The chain up requirements is from a form I got many years ago via the SP office in North Bend Wa, when I was starting to pull my TT to snoqualmie summit. I have seen similar forms in Or, Id, and CA.
IIRC rcw 45.xxxxx is the weight law info.
Marty
โFeb-16-2017 08:36 PM
06Fargo wrote:
So who has actually had a citation or fine for an overweight RV rig?
โFeb-16-2017 08:32 PM
Marty
โFeb-16-2017 08:28 PM
deltabravo wrote:fulltimedaniel wrote:
If you are in an RV you are not subject to these federal and state weight laws.
..unless you are towing or driving an RV for commercial purposes, like being an RV transporter... but then you'd have a DOT number and placard on your truck from the transport company... and in that scenario you are supposed to stop at every truck scale you encounter, if it's open.
In the case when i was doing it, I only had to put a higher weight rating on my vehicle registration for WA State, which is where the truck was licensed. I think I had it registered for 22k.
(someone in an earlier posted mentioned increasing the weight classification of your vehicle registration)
โFeb-16-2017 08:23 PM
Marty
โFeb-16-2017 08:20 PM
โFeb-16-2017 06:04 PM
Searching_Ut wrote:
For those mentioning the risk of facing a lawsuit after an accident, if you look at how that sort of suit actually works, it's what you're worth that determines whether or not you get sued, not whether or not you're at actual fault. That said, I do use a dash cam as it's so common for folks to pull in right in front of you, often so close you can't even see their bumper below your hood.
โFeb-16-2017 04:34 PM
โFeb-16-2017 01:53 PM
โFeb-16-2017 01:01 PM
moresmoke wrote:LarryJM wrote:demiles wrote:
The only one I've seen was down in NC leaving ZMAX dragway and wasn't the normal trailer/fifth wheel. I was following a friend pulling a 30Ft racecar trailer with living quarters and he was pulled over and weighed. He was over his registered GVWR and received a fined which was $150 I think. They told him he was considered commercial because he received money and or products for competing. He also had the usual product stickers all over the side of the trailer.
Over the years I've also read more than a handful of first hand posts usually from Pa concerning weight and or registration fines with these race car trailers with all the advertising and even some where because they could win $$$ they were considered commercial rigs.
Larry
The most common test of this I have heard of is: If you are guaranteed money for showing up at the event - then you would be considered commercial. You are being paid as a performer.
Now some states interpret these rules to their own likes. The 10,000 lb trailer rule is one. Some states have it worded as a trailer over 10000 and GVW over 26000. Others use a trailer over 10000 or GVW over 26000.
I run around to motorsports events in the summer, if I ever get accused of being commercial, I am going to start filing my expenses on my taxes. I bet the IRS will claim its a hobby!
โFeb-16-2017 07:41 AM
Wadcutter wrote:
I have been held for a period because another company driver owed a fine, so they confiscated my truck until the company paid up (still was not wadcutter).
Nope, never did that.
โFeb-16-2017 07:13 AM
rhagfo wrote:Turtle n Peeps wrote:the bear II wrote:
Lawyers will look for overweight RVs involved in accidents
http://www.justaccidentlaw.com/motor-vehicle-accidents/rv-accidents-motor-homes/
Link
LOL, you don't have to be overweight to have an ambulance chaser after you!
Be way over weight and side swipe someone and you're at fault.........guess what....you're at fault.
Be under weight by thousands of pounds and side swipe someone and you're at fault.....guess what....you're at fault!
The problem comes when some idiot pulls out directly in front of you, or pulls directly in front of you and "Break Checks" you and you hit them. They will say it's your fault.
This is the reason I run with a Dash Cam, underweight or overweight, I would strongly suggest all RV's run with them!!
My favorite is always passing lanes on hills, I will be climbing at the speed limit or a bit better, and as I see the lane ends there is this sect in my rear-view mirror and it is trying for all it is worth to get a head of me. If they make it they may need to squeeze into a the space the following space I allow, then typically because that were speeding about 15 mph over what we were all going, slam on their brakes to keep from hitting the car in front of them!!!
Once again, best defense is a dash cam.
โFeb-16-2017 07:05 AM
