sway control
dockmasterdave
I just had to post this one. You won't believe it. I went out this morning to mount my new friction type sway control on our 21' Amerilite. We've had it about a year and use it frequntly for short trips. I figured sooner or later we'd be driving on a windy day, so better to add sway control before I really need it. Looking at the trailer tongue and thinking I got lucky, I'm just going to miss all those bolts on the side of the tongue. Wonder what they are for anyway. Shouldn't be anything there. HEY WAIT there are six of them just like the bracket I'm getting ready to mount. NO WAY YUP a previous owner had sway control, apparently even the same brand. Holes lined up perfect. That became a 5 minute job. How often does that happen. I feel like I should be real nervous right now. It has to be a set up. Oh and a quick question, do most of you use your sway control all the time or only on highways and windy days?
2014 F 150 ecoboost
2008 Chrysler Aspen
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
20 REPLIES 20
MM49
The mechanical sway control devices actually try to control the tow vehicle, not eliminate the sway of the trailer. The real villain in this equation is the lateral movement of the tow vehicle rear suspension.
The new 2014 Ram 2500 has a coil spring suspension with a panhard bar that reduces lateral movement. The bow wave sway performance is greatly improved. Certain combinations of truck and trailers are reporting complete elimination of the bow wave sway.
The 2014 RAM 2500 with the 6.4L gas engine 3:73 will be one of the best performing tow vehicles on the market.
MM49
mike243
Huskey recommends 2 sway bars with trls 24' & over, I bought another & mounted it, better to have & not need than not have & need lol. Pulled mine 230 miles 1 way & very little movement when big rigs blew by. I take them off before doing much backing up trying to set up unit.
boosTT
I use my friction type sway control all the time. I DO set it looser on calm days and short trips though. When its really tight, you can see the brake pad dust it creates.
aftermath
dockmasterdave wrote:
... Oh and a quick question, do most of you use your sway control all the time or only on highways and windy days?
You need sway control for unforeseen predicaments that might pop up. Things like a sudden gust of wind, a large passing Semi, a wet or icy spot on the road and things like that. It makes NO sense to not hook it up. Unless you can look into the future you are taking chances you really don't need to take.
Many people use the "add on" friction bars. Others have anti-sway built into their hitches like Equalizer and Reese do. Either way, make sure you use it.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
jake2250
I have had a manual sway control bar on my weight distribution hitch for the last three years,, seems to work good.
Just bought a 2012 Chevy Silverado 2500 HD, been reading that I have "Stabilitrak" it works with the brakes of the trailer and truck to control sway, also it has a "hill Hold" feature, Along with the locking 4:10 rear, this system is tied into the suspension and brakes and engine functions to control towing... Must be some sort of "Smart Truck"
Crazy_2
We use the Dual Cam also, and it only takes a few minutes to hook up.
So i figure why not use it.
only time I didn't was one time I was repositioning in the driveway for winter.
but if I am on the road the bars are on.
2018 GMC Sierra 2500 HD 6.0L
Grand Design Reflection 297RSDS 8200 Ish LBS dry,
Reece Dual Cam WDH
"If your dog is overweight, odds are you need more exercise"
MM49
They will be standard equipment on several RV OEM's next year.
MM49
PierreBois
I use sway control and have found it effective on my Rockwood 31. I still from time to time feel the suction with a big rig and the lateral winds on open highways. I wondered if I had two, one on each side, if that would be doubly effective, or would it turn my truck and trailer into one solid inflexible mass of moving steel.
2017 319RLS OR 5th wheel
2017 Ram 1500
We travel initially to lose ourselves; and we travel, next to find ourselves. And we travel, in essence, to become young fools again- to slow time down and get taken in, and fall in love once more."
— Pico Iyer
69_Avion
CavemanCharlie wrote:
69 Avion wrote:
MM49 wrote:
The mechanical system will soon be obsolete. They were never effective anyway.
The new systems will be electronic sway control on the trailer.
MM49
Electronic Sway Control
I certainly like that concept better than a mechanical device.
Me too. Although I forgot to check the price. I wonder how well it will hold up over time and how much acceptance it gets in the long run.
I'll bet as they improve, and the price comes down, they will become somewhat standard.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
CavemanCharlie
MM49
69_Avion
MM49
dockmasterdave
Thanks Terry. Good point. I was thinking about winds and trucks on the highways, but hadn't thought about evasive maneuvers. That settled that.
2014 F 150 ecoboost
2008 Chrysler Aspen
2011 4x8 open cargo
Terryallan
Always use sway control, SFTER you adjust the hitch to the point the trailer does not sway. Sway control is made for those times when sway is induced by the driver in an emergency maneuver. Such as dodging a vehicle moving into your lane, or some other road hazard. When you have to jerk the wheel to dodge something. It's then too late to go add sway control.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Terryallan
Terry & Shay
5.0, 3.73
Lazy Campers
