โApr-11-2017 09:55 AM
โApr-15-2017 09:00 AM
Freep wrote:egarant wrote:
I too am going to bit the bullet and go full lithium. Two group 31 drop in's.
I've researched and followed others on their blogs that have done the same. Each person said they would never go back to traditional batteries.
You do have to change the way you charge your batteries. I spoke to Progressive Dynamics, the folks that probably made your converter/charger. They make a lithium charger unit that replaces the traditional one that came in your OEM unit that meets the lithium charging profile.
They are also working with a company called Relion Batteries, a maker of drop in lithium batteries in designing the appropriate charging system.
I've spent a considerable time on the phone with Progressive Dynamics and the folks at Relion and will be making my swap to that setup later this year.
It's only money!
I've been looking into Lithium Iron quite a bit lately too. The dream is to be able to run the microwave without firing up the gen. I think I've settled on the batteries.
https://starkpower.com/product/stark-deep-cycle-12-volt-100ah/
I'm trying to decide if I should get an inverter wired up first to see what kind of hit I take on my batteries when I run the microwave.
I've been looking at the 2000 watt Xantrex Prowatt inverter and I'm trying to figure out where in my 2014 Lance 992 I should install it.
Not sure what to do, still doing research. Any advice is appreciated.
โApr-15-2017 08:33 AM
โApr-15-2017 08:15 AM
โApr-15-2017 06:25 AM
thedavidzoo wrote:
No, we can't run the AC with the batteries, at least not how it is set up now with the wiring. We do have a lower BTU AC unit. I haven't done any calculations to see if it is even possible in terms of watts, load on the inverter, etc.
โApr-15-2017 06:01 AM
โApr-15-2017 05:51 AM
โApr-15-2017 05:43 AM
thedavidzoo wrote:
...We also run a 12V DC compressor fridge.
We installed the system ourselves and thus learned a LOT and saved tons of money! It is an intricate setup, but once it is programmed you can pretty much forget about it. We use the MW with inverter all the time and hardly make a dent in the capacity.
โApr-15-2017 03:19 AM
โApr-14-2017 11:50 AM
It's only money!
โApr-12-2017 01:55 PM
happycamper002 wrote:GordonThree wrote:
. . . I guess you could do regen braking on your RV, the cap soaking up the burst of energy and transferring it to a battery.
Regenerative braking can only be achieved if your MH is totally designed to operate on battery (an all electric) vehicle.
OP's plan is to replace generic batteries with Lithium-Ion, while keeping the old fossil-fueled engine and transmission. There is no mention of converting the rig to operate like a Tesla.
When someone says that one can achieve a regenerative braking to recharge batteries, it makes my training and brain go on a feeding frenzy.
Regenerative power comes from electric motor/s that make the vehicle move. No internal combustion engine, or separate gear variation in the drive train.
As you decelerate the energy of the drive motors (they act like generators) is fed back to recharge the batteries. . . hence the regenerative braking.
If I'm wrong I'll dig up my old notes.
โApr-12-2017 12:40 PM
โApr-12-2017 11:24 AM
โApr-12-2017 10:31 AM
โApr-12-2017 10:30 AM
