Tailgate Clearance
cbwallace
TT has an LCI Electric Tongue Jack but when connected to TV will not allow the tailgate to open more than about half way. It looks like a few more inches of clearance would allow tailgate to fully open, but only option I can find is a manual tongue jack. Does any one know of any other tongue jacks or mods that would get me the few inches I am looking for?
Thanks,
Chris
Chris, Barb, two girls, a Yellow Lab and a Sammoyed
2013 Chevy Silverado 2500 HD Duramax Crew Cab 4X4
B&W Turnover Ball w/Anderson Ultimate Hitch
2019 Grand Design Reflection 31MB
2007 Crownline 252 EX
Kayaks, Quads, Bikes and anything else we can drag along!
23 REPLIES 23
harley4275
I also had this prob on a chev avalanche (I think) and had a barker elec jack and just loosened the allen set screws and turned it 180degrees, like someone else suggested, and it cleared thetailgate.
But new trailer has an LCI jack ...will have to check this spring to see if it can be turned as it hit the tailgate on a 2500 chev pu....hmmm
2013 Sunset Trail 25RB TT
2015 Silverado 2500HD 4x4 6.0 l gasser.
Equilizer 4 pt
From Belle River, Ontario
2003 Mountain Star 890sbrx Truck Camper
Graydust
I have the same problem with my Dodge hd 2500. The tailgate just hits the motor and what a pain getting in the back of the truck. I had planned on making a new sub plate and turn the whole jack but after reading this, I will look at just turning the head. A big thanks here.
pappcam
Dannyabear1 wrote:
DavinD wrote:
Dannyabear1 wrote:
Don't buy a Toyota, problem solved.
Wow! Useful post! Thanks so much for your insightful knowledge on this issue.
Just in case you didn't know, this is one way toyota 'cheats' at tongue weights, by putting their hitch further under the truck closer to the axle. Only truck i've ever has taigat hitting jacks with, and its not the placement of the jacks on multiple trailers.
More misinformation being passed off as fact. Par for the course.
My 2011 F150 has the same issue. I need to get a stinger that's maybe 2 or 3 inches longer.
2023 Grand Design Imagine 2970RL
2011 F150 XLT 5.0
TurnThePage
Bucky Badger wrote:
You are so full of it, my 2010 f150 hits my jack
As does my '97 F150.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
Bucky_Badger
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
JJBIRISH
cbwallace wrote:
The jack has an A-Frame base so would have to turn 60 degrees. While it looks like that would work I am going to opt for the 18" shank. That will provide plenty of clearance not to mention that the TV is overkill for the TT so no danger of coming close to any tow ratings.
you turn the jack head not the whole jack, and turn it 90*...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
_tiredTeacher
Too late, I have one. Oddly ebough, my 2005 Tundra's tailgate wasn't a problem, but the 2010's tailgate is. I got a longer drawbar for my pop up. As for the Rockwood, I'll look into rotating the power jack.
Hey, it's nice to know Ford and Chevy owners are in the boat with me.
Teach
Wright and Penny
2010 Tundra 4X4
2014 Rockwood 2604WS
"Life is a cruel teacher. She gives the test first; the lesson then follows."
cbwallace
I had the same issue with my 2007 1500 Silverado and both receivers are flush with the bumper.
cbwallace
sbowman871
I turned my Ultrafab head 180 degrees. It now clears my tailgate by about an inch. The truck and trailer needs to be almost parallel for it to clear. If the TV is slightly angled it will still hit. TV is a F150.
2010 Everlite 29FK
2011 Ford F150 V6 Ecoboost Max Tow 3.73
Parkit 360
DavinD
That may be true, but how was this at all helpful to the OP?
2018 Coachman Chaparral 381RD
TV - 2013 Ford F350 Diesel SRW 4x4 Short Bed
Dannyabear1
DavinD
Drippin
cbwallace wrote:
I may have just found a solution. I have an Equalizer hitch which I believe has a 12" X 2" shank. Equalizer has an 18" X 2" shank which will give me an additional 6" of clearance which should be enough to allow the tailgate to open.
Chris
This is what we did. The shank is not inexpensive but well worth it.
Don't forget to verify that your pigtail and chains are long enough.
2008 Laredo 284BHS, 2007 Dodge Ram 2500 Quad Cab 4X4 6.7CTD, Equal-i-zer, P3, Subaru RG4300iS :B
