tank level indicator retrofit
JimNH
I have a KZ Sportsmen Classic with no tank level indicators.
The next model up, the Spree Escape, has a tank level indicator panel.
Where is the best place to go to buy parts to retrofit my trailer with a TLI on the grey and black tanks? Anyone done this?
Seems like I should be able to buy whatever system KZ is using on their Spree Escape...I believe the tanks themselves are the same, so retrofitting should be easy.
Thanks for any suggestions you might have!
9 REPLIES 9
Jerry9n
I put in the Horst probes a number of years ago. First I found the mfg of the trailer put the probes in the wrong place (per the level mfgs instructions) so I relocated a couple. Since then they have worked near perfectly. If the black tank doesn't a thorough flushing of the tank fixes that, and for the money, they suit me fine. After 7 years with this trailer I pretty well know how long the tanks will last.
Jerry9n
2009 23' Cikira Escape EXP
2006 Ford Expedition
Reese Pro Series SC
Tekonsha Primus IQ
HTT Mods
IAMICHABOD
Old-Biscuit wrote:
SeeLevel are more expensive BUT OP doesn't have ANY indicators......so See Level would be easiest to install and are a better system because sensors do not contact any of the stuff (stick to outside of tank vs holes thru tank wall)
Good point!
May be a system like This would work too.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Old-Biscuit
IAMICHABOD wrote:
Old-Biscuit wrote:
IAMICHABOD wrote:
The Horst Probes seem the ones that people are changing over to to get best results.
Where can you find them.......thought they went out of business :H
Amazon for the Black
Amazon for the Grey
A lot cheaper than See Level
Wasn't long ago that no probes were available.......:H
THEY are better than OEM which is not much more than a 'bolt' stuck thru side of tank.
JimNH
LLowllms - google which ones? Thank you all...
llowllms
Google them, you can buy them on line and the REALLY work.
IAMICHABOD
Amazon for the Grey
Old-Biscuit
OP.....
IF you really want to install monitor/panel then use the See Level Kit.
They are an external sensors and therefore WORK. But more expensive them the standard stuck thru wall 'stud' types.
SeeLevel
Personally.........
Haven't looked at our level indication in 7 yrs.
I know that we can go 7 days easily and 10 days if needed before dumping.
Besides:
When toilet 'burps'...time to dump
When sink/shower slow to drain....time to dump
When water pump goes 'buuurrrrr'....should have put water in fresh water tank
IAMICHABOD
nomad297
My suggestion would be to forget about it. Tank level sensors are not very reliable. It seems like it would be a waste of time and money to me.
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
