TC and awnings
gorohoff
I currently do not have an awning on my wolf creek 850 but with Spring trips in the wet Pacific Northwest I'm considering getting one. I'm curious to hear others opinions on an awning. They're not cheap, so is it worth the cost, or would I do just fine with tent canopy?
-Andrew
"For all its material advantages, the sedentary life has left us edgy, unfulfilled."
-Carl Sagan, Pale Blue Dot
51 REPLIES 51
mountainkowboy
Our AF had the rear awning and we always used it. The S&S has one on the passenger side and we seem to use it an awful lot too. Awnings are nice to have and I think that if I had a TC without one I would probably put one on.
Chuck & Ruth with 4-legged Molly
2007 Tiffin Allegro 30DA
2011 Ford Ranger
1987 HD FLHTP
kerry4951
AF comes thru standard with the rear awning. Thats why we have it. I did not order the side awnings as Im not a big fan of awnings. I have to say we do deploy the rear awaning if we are set up for extended periods and like it was mentioned it is nice if its raining. The only thing I would like better is if it was a power awning. Alot of the companies I see are going that route. I like yours Billyray. High enough that I wouldnt be smashing my head on the awning arms.
2009 Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilsteins, Hellwig Sway Bar.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, baseboard and Cat 3 heat, 2nd dinette TV, cabover headboard storage, 67 TC mods
billyray50
My 2012 Adventurer came with a Carefree power awning. It is really nice. Notice how far it extends!!
Please note, the maximum photo width=640
gorohoff
For those of you who have awnings, was it already on the camper when you bought it, or was it an upgrade added later?
-Andrew
Reddog1
I think it really depends on your style of camping. Personally, I prefer the tent canopy. I have two 10'x10', a light weight and a heavy duty. Both have screen sides and solid sides. Which one I take depends on the time of year and where I am going. They have worked well for over ten years.
Typically, I use cement stakes and ratchet straps to tie them to the ground, when needed. I have used then if some especially high wind areas, when raining or snowing. They work great for small group gathering, using one or both side by side. I have use my Canopies in camp grounds that do not allow tent camping. When I have ask, I have been told they do not consider the Tent Canopy to be tent camping, just a gathering shelter.
When group camping, I take a foldout table that holds the cook stove and related stuff. I use a 20-pound propane cyl with a tree, heater, and propane light on top. Having the solid sides is nice for heating.
I find the Tents are much more versatile than awnings. Definitely less expensive. I seldom camp where an awning attached to the TC really works well. The awning limits where you can park the TC. The tents can be in front, behind, either side or away from the TC. Very difficult to keep the bugs out with an awning, and not many awnings block the wind other than the TC side. Even blocking the wind on the TC side, the wind blows under the truck into where you have your chairs and such.
The awnings are easier to store and setup, but I do not think as versatile as the tent canopies.
Wayne
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Gripnriprod
We really like our rear awning. We deploy it virtually every time we camp in Alaska as afternoon showers are common. This really helps keep from tracking mud in and gives me a place to get out of my waders, stay dry and hang wet stuff. While it doesn't cover a large area, it is still effective in providing a dry area adjacent to the camper rear entry.
'11 GMC 3500hd SLT DRW D/A 4x4 Spray-in, Air Bags w/comp & controls, TL, Superhitch, 48" Supertruss, 9.5t Warn, front rcvr, Fox Shocks, '11 AF 1140, DB, AC, Gen, Solar, Thermal Windows, Wardrobe, Rear & Side Awnings, 18' Lund/40hp Honda 4 stroke
fatmanobx
I like having the one on the back of my tc..I can leave the door open when it's raining and it doesn't seem so closed in when having to stay in for a while. It's nice to have a nice dry area to keep things under..jmho...
2011 Lance 855
3.5# Minpin named Darcy RIP
Ford F250 Super Duty
