The AHHH SH** MOMENT
mike_mck
So went looking for the 2 key set for my 96 Caribou. 1 for the entry door and 1 for all the access doors. Missing in action.
Can't get to the battery or fresh water fill.
Options to replace locks? Any ideas?
Sent an email to Fleetwood this morning with S/N but thinking too old for them to be able to replace keys.
Tear them open and replace everything? Huge job.
Lock smith? Expensive.
Anybody had this issue? Please tell me I'm not the only bonehead:S
14 REPLIES 14
clikrf8
I keep our extra sets in a lanyard around my neck. Since hubby does most of the driving, mine are there just in case. He is always misplacing his in cargo pants pockets after he sits down.
2008 Ford F250 SuperDuty 4x4 Off Road Pkg Diesel Ranch Hand Sport Ride Right airbags
2013 Hallmark Ute LX
Toller Mousse: Chocolate Standard Poodle cross
Blitzen: Black Standard Poodle
Photography Website
Photography Blog
AnEv942
Good deal-FIC door keys 2.75 plus shipping if local shop doesnt have correct blank
rvlocksandmore.com
Disregard letters if ordering key, the last 3 numbers is what you need to order key.
The outside cabinet CH751 key 2.00
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
mike_mck
mike mck wrote:
Super_Dave wrote:
Mike, have you only ever had one set of keys? I keep one set on my truck key ring and one set in my glove box.
Oh sure rub it in. 🙂 It was the first thing I was going to do when I bought the TC 8 months ago. Still on my to do list.
Well the end to the Saga was the least expensive. Locate the keys. I have no idea how they found their way into the cabinet below the bathroom sink. Well I learned my lesson. I'm getting a second set made. Tomorrow, Maybe;)
At least this thread and another related thread will educate many of us unfamiliar the exterior locks on our RV's.
The beauty of the Woodall forums
mike_mck
Thanks for all the info. Seems I may get out of this realitivly cheap with biggest damage to my pride.
mike_mck
Bigimac
I the truck key; storage key; TC door key; hitch lock key; Thule rack key; all on 1 key chain, with the extra set in the glove box.
A locksmith charges $75 to open the door after locking all these keys in the truck ...
2013 Capri Sportsman Grande
2015 Chevy Crew cab 3500HD SWD gasser
Toyo Open Ctry ATII 275 70R/18
10150# loaded; 10.5 mpg @ 70mph
AnEv942
Yes the compartment doors likly the standard CH key.
IF you had the number written down for the FIC (Fastec Industrial Corp.) main door key it can be ordered..should be 3 numbers stamped on key. I think the numbers are also stamped inside the lock if you or once get access. Replacement keys are available but need the number. I keep our spares in truck. I have the number written down-in the campers manual- which is in the camper...
On ours the rear compartment door which opens to dinette seat box is large enough for a child to enter. Either lifting up the seat box top, have to finangle the cushions- or possibly thru inside cab door, to open the main door from inside.
I havnt a clue what lock smith would cost-Id call around. Given options might be cheaper before tearing stuff up. Outside cab you can buy key- main door breaking door window would offer opportunity to change it out to clear. Wouldn't think cheaper-
Edit- as LOWELL731 mentioned there is a master key for the FIC locks- taking camper to dealer in your area they could open for you. And sell new keys.
FIC keys
Super_Dave
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
Boatycall
deltabravo wrote:
sharker6 wrote:
Most of the RV industry uses the same keyed lock for the compartments.
CH751 is the key number for most compartment doors.
Fleetwood - they won't be of any help since they are long gone from the business of building smaller RVs and truck campers...
x2... In case you were not aware, Any of us can open anyone else's outside cabinet doors.
CH751 is the standard key for all RV hatches. Go to any RV parts store, buy a lock and key set, that key will be a CH751.
'15 F450, 30k Superhitch, 48" Supertruss, 19.5's, Torklift Fast Guns
'12 Eagle Cap 1160, 800watts solar, Tristar MPPT, Magnum Hybrid 3k Inverter
'15 Wells Cargo 24' Race Trailer, 600 watts Solar, TriStar MPPT, Xantrex 2kw inverter
'17 Can Am X3 XDS Turbo
deltabravo
LOWELL731
When I was a dealer I had master keys.Check with a dealer.
Lowell
RoyB
Borrow your neighbors key to get it open. Also most of the aluminum structure walls will bend enough to gain access with just using a large flat blade screw driver with no damage to the door jams.
My truck has the PUSH BUTTON DOOR ACCESS for the drivers side so I keep all my spare keys etc in the truck glove box.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
sharker6
Most of the RV industry uses the same keyed lock for the compartments, like buzzcut stated.. Many entry doors are keyed alike also
2017 Keystone Cougar 29RES, 2008 F250 Diesel FX4
Buzzcut1
Nomad II
Nomad II
the access doors should be a common lock for most RVs. copy the number on the lock and go to an rv place. I will bet you can buy a lock and key with that number for a couple of bucks which will give you access to the compartments.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
