โDec-29-2018 04:54 AM
โDec-30-2018 01:47 PM
โDec-30-2018 12:35 PM
โDec-30-2018 11:33 AM
โDec-30-2018 10:05 AM
โDec-30-2018 10:04 AM
ksss wrote:ShinerBock wrote:
I think each manufacture should be forced to send their most popular power train configuration. GM keeps sending their 6.2L to just about every truck test, but I doubt it is sells more than the 5.3L by a long shot.
I am sure they do sell more 5.3's than 6.2's but if you want the ability (and you have the billfold) of the 6.2 you can buy it. I don't see that being an issue. If it was some kind of special edition I would absolutely agree, but a 6.2 is not that. It is easily obtainable. It is just that a lot of people don't need that much motor or are not willing to pay for it.
โDec-30-2018 09:50 AM
MikeRP wrote:
Maybe the manufacturers ought to do away with 2500โs.
โDec-30-2018 09:33 AM
โDec-30-2018 08:11 AM
โDec-30-2018 07:19 AM
4x4ord wrote:Samsonsworld wrote:
One, I've never seen an engine run at full throttle that didn't get hot. Two, fuel has nothing to do with the tranny. If that torque converter slips, it heats up fast. Also a problem running full throttle.
You're right than when you run an engine at high rpm and full throttle things get hot. The reason is that the engine can produce more power at full throttle high rpm.
In this test, all the engines put similar power to the rear wheels. If the Ram transfered that power through its torque converter at the highest rpm it transferred its power through its torque converter at the lowest level of torque....less slippage....less heat generated.
โDec-30-2018 06:36 AM
โDec-30-2018 06:17 AM
โDec-30-2018 04:12 AM
โDec-30-2018 03:48 AM
โDec-30-2018 02:45 AM
