โAug-24-2017 06:17 PM
โSep-02-2017 09:55 AM
Old Blue wrote:
If it were mine, I would change the boat plug to a 7way plug and just hook up the 4 wires and be done with it...
Bill
โSep-02-2017 09:54 AM
newman fulltimer wrote:
why would you plug both in at once:h
โSep-01-2017 10:48 AM
โSep-01-2017 07:49 AM
โSep-01-2017 07:46 AM
Wardster wrote:
Just remove the spring door
โAug-26-2017 11:07 AM
โAug-26-2017 10:25 AM
โAug-25-2017 03:46 PM
โAug-25-2017 08:55 AM
โAug-25-2017 08:41 AM
robertjp wrote:mkirsch wrote:
Poor design, because one person in a million has a weird corner case where they need both connections at once?
So only 1 in a million pull a boat with a truck camper?? Seriously?
โAug-25-2017 08:29 AM
Yeti plus wrote:
There is a coiled up wiring harness on the frame just behind the cab on GM trucks to install in the box of the truck for fifth wheel and truck campers. Put that into the box and hook up a 7 pole female plug to plug the camper into, and then the plug on the bumper is good to go for your boat.
On my 2014 I just popped out the plastic cap that GM put on the front wall and fed the wires through put the receptacle on the end of the wires because I couldn't bring myself to drilling a big hole in the side of the box to mount the plug into.
Brian
2014 only has 7 pole plug at bumper.
โAug-25-2017 08:11 AM
โAug-25-2017 08:02 AM
โAug-25-2017 07:42 AM
