Tire and wheel weight ratings
karenor59
I have a 10.6 Bigfoot camper on a 2000 Ford F350 crew cab long bed 4WD SRW. The rear axle weight loaded is 7380 lb. I want to put BF Goodrich TA KO2 285 75R 16 load range E tires on it. The load rating for these tires is 3750lbs. ea. for a total of 7500 lb. The load rating for the stock 265 75R 16 is 3415 lb. for a total of only 6830 lb. I can't find a load rating on stock wheels or find wheels this size that are rated for 3750 lb.
I want to use the BFG's because they have reinforced triple side walls. I travel on bad roads and have had trouble in the past with the failure of lesser tires.
Any suggestions? Thank you.
22 REPLIES 22
SoCalDesertRid1
I hope Stockton gets their carp in order. They made an excellent product and had the market cornered too. No reason for them not be successful with it again, unless they're badly mismanaged.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
SoCalDesertRid1
Jefe,
I think your idea would fly with greater success, if the weight rating per tire were increased to about 5500 lbs. This would open up a new market of dually pickup owners wishing to replace their rear duals with a super single for better off road use, which can still maintain the ~11,000 lb rating of their combined 4 original rear tires. A 4500 lb version could be offered as well, for those SRW pickup owners who want something part-way in between a typical SRW and DRW rear axle weight rating.
98Ranger 96Tacoma
20' BigTex flatbed
jefe_4x4
SoCalDesertRider,
Long time no see in print. June 15th and no wheels yet. Someone on here did mention that one of their Stockton whees did fail, but that was before the owner committed suicide and there was a shakeup with the company who now claim they have nothing to do with the pre-suicide Stockton Wheel. Boy, that's ugly. Time will tell.
My favorite truck camper tire of all time is/were the Mickey Thompson 375x55R16's (33x15.50R16) on 12 inch wide rims that are breathing their last. They have lasted and lasted for years with a lot of hard miles on them. They wear very slowly. Simply the best all around TC tire that will work on sand as well as street, in any weather. We have put 2500 miles on the rig on two sorties along the coast and they are getting down to the wear bars.
I was tempted to call Thompson Tire to see if they could produce them again with some changes. I'm thinking their marketing was all wrong. What if you could have a super single tire that would take place of a set of duals with a 4500 pound rating and also an aggressive All weather tread. Once you have pressure down to floatation levels the tread doesn't matter so much on sand. The term, "Grave Digger", a skinny aggressive mud/snow tire was called that because the users had no clue about deflating them down for floatation. To seal the deal, Thompson (or someone) would have to make, say an 11 inch wide super single wheel for the rear axle with a 4500 pound rating (with a 4-1/2 inch B.S.) to go along with the upgraded tire. Now, would anyone buy such a rig? I don't know. There seemed to be very little interest in my super single design on here when I put it together about 6 years ago.
jefe
'01.5 Dodge 2500 4x4, CTD, Qcab, SB, NV5600, 241HD, 4.10's, Dana 70/TruTrac; Dana 80/ TruTrac, Spintec hub conversion, H.D. susp, 315/75R16's on 7.5" and 10" wide steel wheels, Vulcan big line, Warn M15K winch '98 Lance Lite 165s, 8' 6" X-cab, 200w Solar
Grit_dog
Navigator
Navigator
karenor59 wrote:
I decided to go with the Vision rims 4500 lb rating and Gladiator QR90-PT 4850 lb rating. Any recommendations for a brake upgrade kit?
Doing it right!
Do you need brakes? Or are they working fine but want more braking power?
Suggestion, if there's nothing wrong with them now, but you're not comfortable with braking performance, spend the brake upgrade $ on an exhaust brake instead.
karenor59
JIMNLIN
WHEEL SPECIFICATIONS
Max. Wheel Capacity Load (lbs. @ ground)
Steel (SRW) 16? x 7.0? K 0.25 8 170 (6.7) 3415
Steel (DRW) 16? x 6.0? K 5.35 8 170 (6.7) 2600
Steel (DRW) 19.5? x 6.0? RW 5.35 8 225 (8.85) 3750
Steel (DRW)(MOTORHOME) 19.5? x 6.75? RW 5.50 8 225 (8.85) 3750
Deluxe Forged Aluminum (SRW) 16? x 7.0? K 0.25 8 170 (6.7) 3415
Premium Forged Aluminum (SRW) 16? x 7.0? K 0.25 8 170 (6.7) 3415
Polished Forged Aluminum (DRW) 16? x 6.0? K 5.35 8 170 (6.7) 2600
Polished Forged Aluminum (DRW)(1)
Looks like 3415 lb capacity Per '00 Fords body Fords fleet service guide page #58 fleet ford
SoCalDesertRid1
Jefe, it's sad that your awesome, giant super-single rear tires are now discontinued! ๐Ÿ˜ž
The 18" tires do have greater weight ratings available, but I agree, more sidewall with the 16" wheels is better off road and you're just within the 7500 lb combined rear tire rating with the 285 16's.
98Ranger 96Tacoma
20' BigTex flatbed
SoCalDesertRid1
The Ford/Sterling 10.50" axle housing is rated at 9750 lbs in the '99-'04 F250/350SRW/350DRW pickups, per the axle manufacturer.
Stockton Wheel custom made me a pair of 16x8 heavy duty steel wheels for my '92 F350SRW back in late '07, which my truck still has on the rear axle, some 9 years later, with 285/75-16E BFG AT's, rated 3750 each.
These wheels and tires have carried 4000 lbs of utility body and welding equipment in the bed of my F350 from '08-'12, the years I used it as my welding truck, as well as pulling my trailer at the same time. The truck carried my old 8' truck camper (about 2500 lbs) and pulled trailer from '03-'07, with the old 16.5" wheels and 33x12.50 BFG's on it. Now it carries another 8' truck camper on it with the Stockton wheels and 285's.
Never had any problem whatsoever with the Stockton wheels or that model/brand/size tire carrying near the maximum weight for so many years.
The Stocktons are very heavy duty, with solid 3/8" thick flat disc steel centers and thick wall DOT rim shells. I think there still may be my write-up about the wheel/tire upgrade posted in the truck camper help section from several years ago.
98Ranger 96Tacoma
20' BigTex flatbed
jefe_4x4
All of the newer DOT approved truck wheels I've had, both factory and after market have the weight rating stamped on the inside, backspacing part of the wheel. I'm not sure, but i think this is a DOT requirement after a certain year.
However, this is only a guide, as real world use has shown a wide range in strength of wheels. My 16"x12" wide Mickey Thompson cast aluminum wheels are stamped at 3600 pounds. They are very hefty with a thick almost solid center. I have put these to the test over and over on rough ground, with my rear axle loading ground pressure of around 6800 pounds. My guess is these are over built for the rating. Yes, I'm using non-scientific, personal use as the yardstick to the ever expanding dismay of the purists. The only casualty so far has been a strip chipped out of the rim edge from a passing rock in Death Valley. But it still holds air. These big, discontinued (boo-hoo) 375/55R16 tires have one more long trip left in them.
In the meantime, after a long and fruitless search for more heavy duty wheels for my XTC I've engaged Stockton Wheel to make me a set for my Dodge SRW D-70/D-80 axles. They should be here by June 1st. Why not just buy aftermarket wheels you ask? I'll be writing a complete expose on the TC wheel business with examples and whys and what fors. I"ve ordered two front wheels: 16x10 with a 6.25 inch backspacing. Two rears also 16x10 but with a 4.5 inch backspacing and will be using Cooper STT Pro LT315/75R16; E/3860 pound rating; recommended wheel size: 8 inch to 11 inch wide; 34.53 inch diameter;11.7 inch wide carcass; 9.69 inch tread.
I know, you're thinking I should have gone with 19.5's for carrying ability. These do not work well in sand. I spend some time in the dunes, so with low pressure the 16" wheels and tires should be fine.
The choice I faced was with 18x10 inch wheels which could hold the Cooper STT's; LT295/70R18's which have a 4080 pound load rating. Respectable. Oh so tempting but not enough sidewall for me. I need lots of air space to float on once I drop the pressure to 22 pounds.
jefe
Steve_in_29
Oregun wrote:
What size tire on the 19.5 spare fits underneath?
Any tire/wheel combo up to a 35" diameter will fit in the spare location on a Super Duty. My 305/75R18 (35") fits just fine with some room to spare even.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
lonegunman
Factory DOT certified wheels are probably the best bet for hauling anything. If they are rated at 5,000lbs, they can probably haul double that, Ford factory rims are incredibly stout. I'd prefer a forged aluminum factory wheel to a cast Chinese wheel any day of the week. 95% of what's available aftermarket is chinese made no matter who stamped their name on it.
It has been discussed ad nauseam here, the axle in an F-350 is easily capable of hauling more than 10,000lbs, it is the tires and wheels that make the difference. If your tires put you at 7,5000lbs, they will haul that easily day in and day out if properly inflated and maintained.
I have absolutely no problems with factory 18" rims and Michelin tires. If the new BFG's will fit your current rims, you are fine.
Buzzcut1
Nomad II
Nomad II
245/70R19.5 fit with ease. same diameter as a 285/75R16 that I had there before.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Oregun
Buzzcut1 wrote:
karenor59 wrote:
Buzzcut1 wrote:
I went the similar route on my 03 F350 running Toyo Open Country HT with tuff duty side walls in the 285/75R16 rated at 3750. Had a blow out in the rear with one of them at 6 months old on I5 at 65mph. $3500 damage to the bed and I almost rolled. I ditched that idea after that and went to 19.5s with 4850 tires on 4500 rated Vision rims and never looked back.
I still have that truck and tire set up for towing my horse trailer on day trips while the Dually now carrys the TC and horse trailer on multi day shows and any trips with just the TC
How did you handle the spare?
another 19.5 on a vision rim. fits the F350 just fine as a spare underneath.
Buzzcut1
Nomad II
Nomad II
