Jul-27-2020 05:28 PM
Aug-01-2020 07:06 AM
Jul-31-2020 07:53 AM
Jul-30-2020 01:01 PM
Bionic Man wrote:v2k wrote:
I run 80 lbs in the tires. I will have to try running with less air when not pulling.
I am leaning toward the Continental Terrain A/T tire from Discount tire. I was hoping to get some reviews.
Every tire is going to ride rough at 80 psi when empty. Your current brand is not the problem. Your running psi is.
Jul-30-2020 07:10 AM
Jul-29-2020 10:47 PM
monkey44 wrote:
Be careful running too low on HD "E" tires, if you do, the sidewalls might crack and come apart while driving. I run mine at 65 empty and 75 hauling the TC. That seems to work fine, and I get a nice ride at both pressures. My truck wears BFG 285/70 "E" shoes ... 🙂
Jul-29-2020 08:00 PM
Jul-29-2020 01:18 PM
Jul-29-2020 10:49 AM
Jul-29-2020 09:49 AM
Jul-29-2020 08:58 AM
Bob E. wrote:
I have Firestone TransForce AT's on my truck ('13 Ram 2500) and most of my driving is just running around empty. So I drop rear pressures down to about 50psi. When I'm loaded or towing the camper, I up the pressures to 80psi per the sidewall max pressure. I'm on my 3rd set and got 50,000miles out of each of the first two sets (which is why I keep buying them)...and probably could have squeezed a bit more but snow was coming.
Jul-29-2020 08:57 AM
Jul-29-2020 08:53 AM
Jul-29-2020 08:42 AM
Jul-29-2020 06:04 AM
