Aug-06-2021 01:18 PM
Aug-12-2021 03:58 PM
phillyg wrote:
There's nothing wrong with using max 80psi for your E-rated tires. Set when cold, i.e., not driven on. All tires with get hotter and psi will go up as driven. No worries as that's factored in by tire engineers. The hottest I've ever seen my FW tires is 135 on a hot summer day. If you choose to go with F or G-rated tires, you'd still be limited by your axle rating, and you should first determine if your wheels can take 110psi.
Aug-10-2021 06:07 AM
Aug-09-2021 08:39 AM
Kayteg1 wrote:Thank you for taking a selected snippet of my statement out of context.time2roll wrote:
Certainly never below the door sticker.
My 12' long camper was taking about 400 lb from front axle.
After having it weighted, I lowered from recommended sticker value, to tire manufacturer value for actual weight.
Per tire manufacturer, when my empty dually was showing 2800 lb (do I remember it right? ) on rear axle, I should drive with 30 psi.
Obviously for short periods of empty driving I did not play with it, but the results were pretty harsh, regardless Sulastic hangers.
Without the hangers I was afraid to drive empty over street covers.
Aug-09-2021 08:32 AM
Aug-07-2021 12:04 PM
BSWS19 wrote:
Setting the pressure at "cold" temperature makes sense to me but, do I need to compensate any in AZ when "cold" tire temps can be 80 to 90 degrees? I usually set mine about 5 psi less than recommended and still see highway temps of 100 to 110 degrees.
Aug-07-2021 11:11 AM
Aug-07-2021 10:19 AM
Aug-07-2021 09:34 AM
Aug-07-2021 09:13 AM
TCCamperNoob wrote:For about any truck camper you will want to run the rear at the sidewall max. Best to get on a scale to compare to the RGAWR and the tire inflation chart. Is that an oversize tire or OEM size?
Hi All, I'm new to all this truck camper stuff. I recently went out on the road and had my tires filled to Ford/tire requirments cold (75 rear, 60 (front). All said and good, right? However, on the road my tires got up over the max pressure of 80psi, like 81-82. Is this normal or should I set cold temp lower? I'm using Wildpeal A/T3W tires LT275/70R18. Any advice would be appreciated. TIA
Aug-07-2021 09:09 AM
BSWS19 wrote:Cold is in the morning, before you drive, and before the sun is on them. Does not matter where you are, what the temperature or elevation is. Frankly I recommend 5psi over the door sticker not to exceed sidewall max. Certainly never below the door sticker.
Aug-07-2021 08:58 AM
Aug-07-2021 05:26 AM
Aug-06-2021 04:58 PM
WNYBob wrote:
For carrying a TC you might want to go up in tires and get load rated D or E. They have stiffer sidewalls, therefore less flex and less heat.
Aug-06-2021 04:45 PM
