โNov-05-2014 06:57 AM
โNov-06-2014 08:09 PM
jadatis wrote:
If you give needed data , I will give a picture of my filled in spreadsheet in my answer with adviced pressure for your situation.
โNov-06-2014 09:27 AM
โNov-06-2014 02:04 AM
โNov-05-2014 01:27 PM
โNov-05-2014 11:18 AM
Tires deform; they don't compress, so the air pressure remains the same regardless of how much weight you put on them.
โNov-05-2014 09:13 AM
mkirsch wrote:
Before or after you load, doesn't matter. Tires deform; they don't compress, so the air pressure remains the same regardless of how much weight you put on them.
โNov-05-2014 08:47 AM
โNov-05-2014 08:36 AM
โNov-05-2014 08:26 AM
deltabravo wrote:
I put them at the PSI that is indicated on the door jamb sticker, which for my DRW 09 Silverado is 66 PSI front and 60 PSI rear, stock tire size.
โNov-05-2014 07:52 AM
โNov-05-2014 07:39 AM
โNov-05-2014 07:03 AM
