Aug-07-2017 12:17 PM
Aug-09-2017 10:13 AM
Aug-07-2017 09:18 PM
Aug-07-2017 07:02 PM
Aug-07-2017 03:02 PM
Aug-07-2017 12:58 PM
rwiegand wrote:
The "sticker" pressures are largely based on ride comfort at some assumed typical (low) load The tire labels are related to the load capacity of the tire. Go with the tire manufacturer if you are pushing towards the load limit on the truck. You're trying to have the tire be in full, even contact with the road, all the way across the width of the tire. If your tires wear more in the center your pressure is too high, if they wear at the edges it is too low for your load.
Aug-07-2017 12:36 PM
Aug-07-2017 12:33 PM
towpro wrote:Agreed
The chevy saying 35psi is based on weight of truck (full), the 51 on tire is based on design of tire with max weight on tire.
yes you can go over 35psi.
Aug-07-2017 12:23 PM
