Aug-12-2014 07:13 PM
Aug-17-2014 06:22 AM
Porter4dmfd wrote:
If it were me, I'd use 4x4's as cribbing. I'd cut them at least 16 inches long. I wouldn't leave the jack fully extended either. I'm not saying the jack won't hold it, but things get pretty wobbly when the jack is fully extended
Aug-16-2014 02:00 PM
Aug-13-2014 06:59 PM
Bucky Badger wrote:ragged claws wrote:
I want to thank everyone for all of your suggestions. I think I've solved my problem. I bought a dirt bike stand from Harbor Freight for about $30. It's made of steel, only weighs about 10 pounds, and is rated for 1000 lb. load. It's 16" high. I made a leveling pad out of some 1x6 with some 1/2" plywood screwed to it. The stand with the pad under the down slope bottom rail is perfectly level in my driveway. I was able to get my trailer perfectly level, fore and aft, with this stand and two 2x6s stacked on top of the stand. The tongue jack is only half extended now. Everything seems a lot more stable without so many 2x6 blocks stacked under the tongue jack. I still have a lot of 2x6s stacked under my front stab jacks, but I'll remove those when the 6 ton jack stands arrive from Amazon in a couple of days.
Once again, thanks for all the suggestions.
Kim
This one? Looks like a good idea
http://www.harborfreight.com/dirt-bike-stand-67151.html
Aug-13-2014 05:39 PM
Kim
Aug-13-2014 05:31 PM
Aug-13-2014 05:20 AM
ragged claws wrote:Dannyabear1 wrote:
What about 2 concrete (cinder block) instead
I've read that cinder blocks can crumble under load. That would be a great option otherwise.
Aug-13-2014 04:59 AM
Aug-13-2014 03:41 AM
westend wrote:
Any tree trimmers in your area? A piece of tree works very well for stability and can be rolled out of the way when not in use. Lacking that, I would buy some 6 x 6 and make cribbing to reach your height. I've supported thousands of pounds with both methods.
Aug-13-2014 02:19 AM
Jaxom wrote:
Could you use a Hi-lift jack to level it after unhooking from tow vehicle? That would eliminate the multiple jack & block scenario.
Aug-12-2014 10:16 PM
Aug-12-2014 09:54 PM
Aug-12-2014 09:53 PM
Aug-12-2014 09:37 PM
Aug-12-2014 08:44 PM
