โAug-22-2014 09:56 AM
โAug-26-2014 08:01 PM
STOP the assumptions it had something to do with the truck, trailer, or set up.
โAug-25-2014 07:27 AM
blt2ski wrote:
Cummins,
I doubt more truck would have helped. I have been dang near swung around once with my 12K dump truck pulling a bobcat on my ET with the trailer being around 8K lbs. Too little hitch wt! A singel axel trailer with a pallet of sod on the rear, dang near took out a 1 ton dually pulling it, again, due to too little HW!! BIG twucks do not stop issues like this. THey can get swung, moved by the trailer too!
My pic is not working, as the photo hosting company has gone ALL pay for to show pic like this etc. what a pita!
marty
โAug-24-2014 09:29 PM
โAug-24-2014 08:50 PM
โAug-24-2014 08:09 PM
โAug-24-2014 08:06 PM
dodge guy wrote:camperforlife wrote:
It is a 1500. The tailgate edge is slightly scalloped on the bottom where the screw indents are as they are only on the 1500's. 2500's have a straight edge & are glued on.
And there is a slight "crook" to the body line at the front of the fender, and the 1500`s had a run in the paint just at the rear edge of the front fender, anyone that knows GM`s would know this!!!! :S
:B
โAug-23-2014 03:38 AM
WE DONT KNOW WHAT HAPPEND.
โAug-22-2014 11:03 PM
โAug-22-2014 10:20 PM
โAug-22-2014 08:49 PM
โAug-22-2014 08:13 PM
โAug-22-2014 08:01 PM
โAug-22-2014 07:59 PM
blt2ski wrote:
I would agree, that too little hitch wt was probably the cause. Been there done that pulling my bobcat with my MDT dump truck. Has ZERO hitch wt, and trailer was moving back and forth. Moved the bobcat forward so I had the typical 800-1000 lbs HW for the total usually in the 7500-8500 lbs tween axel and HW depending upon tools, extra bucket and fork attachment I sometimes carried at the front.....Pulled straight as an arrow.
BUT with that in mind, the truck does look 1500'ish IMHO. So probably a bit over tailed for my sence of well being.
Here is my combo with the 2800 lbs mini trackhoe, bobcat....usually about 10500-11K on the axels, 1400-1600 hitch weight! assuming the link works......
โAug-22-2014 07:33 PM
