tow with all wheel drive?
LVJJJ
Our 94 Suburban cracked a head so were looking for a newer Suburban. Many of them seem to be all wheel drive, can you tow with those?
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
25 REPLIES 25
opnspaces
Navigator II
Navigator II
My 2001 Suburban. I think I put it in Auto once just to see if it worked.
Grit_dog
Navigator
Navigator
But most every Tahoe/Burb from GMT800s on has an auto setting which is effectively awd. But itโ€™s switchable back to 2wd.
Some current platform GM 1/2 tons donโ€™t have 4lo anymore. Guess not many use it much or at all. Me included. With the power and electronic control of basically any 4wd in the last few decades, 4lo is only really useful for crawling in steep country. Not something alot of snack wagons with full length running boards doโ€ฆlol
None of which affects any of their abilities to tow, but to answer the OP more specifically
blt2ski
Moderator
Moderator
I'll swag the burbs are like my 1500 pickup. You get a dial on lower left of dash, rwd is to the left, turning to right you get AWD, 4h, 4l options. I run in rwd 90+% of the time. AWD if it slushy, 4h if I feel I need 4wd. Previous rigs when towing in snowy areasi didn't have AWD option, used 4H.
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
Grit_dog
Navigator
Navigator
Although LLVJJ is one of the those post n disappear folks. Although to be fair they donโ€™t actually have a question that needs anyoneโ€™s help answering.
Grit_dog
Navigator
Navigator
deltabravo wrote:
ktmrfs wrote:
deltabravo wrote:
Tahoe / Suburbans are 2WD or 4WD, not AWD.
not true. there are versions with AWD as well as versions that don't have a center diff and are 4wd or 2wd.
Show me. I looked at the vehicle configurator and all I see are 2WD and 4WD options. The brochure also shows 2WD or 4WD, with 4WD being standard on the Z71 package.
DB WTH are you taking about? Youโ€™re loosing it hereโ€ฆ.re-read what youโ€™ve writtenโ€ฆ
The brochure? Lol. Literally no one knows or has singled out a particular model or platform other than apparently newer than 1994โ€ฆ.
deltabravo
2009 Silverado 3500HD Dually, D/A, CCLB 4x4 (bought new 8/30/09)
2018 Arctic Fox 992 with an Onan 2500i "quiet" model generator
ktmrfs
2011 Keystone Outback 295RE
deltabravo
opnspaces
Navigator II
Navigator II
My 2001 is the same as above (Auto, 2wd, 4hi, 4l) I just leave it on 2wd. My guess is sellers are listing them as Auto 4wd because it sounds like a bonus selling point to them.
Grit_dog
Navigator
Navigator
Lol, what?
And Iโ€™m not aware of any GM full-size suv that is full time AWD. Not that it would matter.
Iโ€™d suggest doing some more research privately until youโ€™re able to discern between drive systems and read towing capacities.
Wouldnโ€™t even have a question if you actually looked up the towing cap for the rig youโ€™re presumably considering.
wnjj
Our '14 Yukon XL has 2WD, "auto" and 4WD. The middle setting is computer-controlled clutching that drives the front when needed but can run on pavement.
There are other models with 4WD Lo + neutral as well.
I don't know of any other "AWD" configuration and either of the above should be fine for towing at least up to the rating.
