โMar-22-2017 06:09 AM
โMar-26-2017 03:28 PM
johndeerefarmer wrote:ShinerBock wrote:johndeerefarmer wrote:
Anyone towing heavy, in the heat or mountains should be running premium anyway. If you don't the pcm will be pulling timing and taking away power that you need.
Yes the 6.2 gasser beats the ecoboost in towing fuel economy but it doesn't have the low end torque of the ecoboost and I have no interest in driving a truck that is constantly downshifting like NA trucks do. The ecoboost has the low end torque similar to a diesel but hp numbers more like a gasser. They are great at both acceleration and towing.
The ecodiesel is way low on hp and wouldn't be worth a darn for acceleration or passing
I pulled over 9k over the Rockies from Texas to Moab Utah twice and never used premium in my 2011 EB.
Do what you like but you are leaving power on the table. Then throw in the small CAC on the ecoboost and you are losing even more power due to excessive IAT2 temps. Put an aftermarket CAC on it and it will quit retarding timing as IAT2 rises
โMar-26-2017 02:48 PM
โMar-26-2017 02:29 PM
โMar-26-2017 12:20 PM
โMar-26-2017 10:27 AM
โMar-26-2017 10:19 AM
โMar-25-2017 05:34 AM
mooky stinks wrote:
My 15 6.2 will ping like crazy with 87. I run a mix of premium (93) and 87 to reach 90-91 octane and straight 93 while towing.
โMar-24-2017 06:09 AM
โMar-24-2017 04:45 AM
Bionic Man wrote:
"what I am not wanting to post"? Really? Seems to me I am the one that posted the link to the owners manual.
The link, which CLEARLY states that "for best overall vehicle and engine performance, premium fuel with an octane rating of 91 or higher is recommended".
You can add your own adjective of "power" if you want. Ford did not put it in there. You did. Maybe they wanted to say for the best engine longevity, use premium. Maybe they wanted to say "for the smoothest performance, use premium".
The owners manual states they recommend Premium. They don't say why. I take it at face value.
The sky is blue. Let's argue about that.
โMar-23-2017 09:19 PM
โMar-23-2017 09:10 PM
โMar-23-2017 08:54 PM
โMar-23-2017 08:51 PM
ShinerBock wrote:Bionic Man wrote:
No. It says:
For best overall vehicle and engine performance, premium fuel with an octane rating of 91 or higher is recommended.
But you are never wrong. So I am done.
Why are you not posting all that it says?
Here, let me post what you are not wanting to post....
"Your vehicle is designed to operate on regular unleaded gasoline with a minimum pump (R+M)/2 octane rating of 87.
Some fuel stations, particularly those in high altitude areas, offer fuels posted as regular unleaded gasoline with an octane rating below 87. We do not recommend these fuels.
For best overall vehicle and engine performance(i.e. POWER) , premium fuel with an octane rating of 91 or higher is recommended. The performance(i.e. POWER) gained by using premium fuel is most noticeable in hot weather as well as other conditions, for example when towing a trailer. See Towing a Trailer. "
Again, it is designed to run on regular, but if you want more power, then run premium. How is this so hard to comprehend?
โMar-23-2017 08:42 PM
