Apr-18-2015 12:20 PM
Apr-21-2015 01:55 PM
Apr-21-2015 12:45 PM
Apr-21-2015 07:41 AM
colliehauler wrote:
I would give it a try. It sounds like you are well aware of weight and possible transmission issues. You also said you are willing to upgrade tow vehicle if it isn't satisfactory. Removing the seats and loading light should have you under weight rating.
I hope you enjoy your new trailer and make a lot of good memories.
Apr-20-2015 07:03 AM
Apr-20-2015 06:41 AM
Apr-20-2015 04:24 AM
VentureVan wrote:And that is exactly your problem. Payload is what your van is carrying which includes people gear, your WDH and tongue weight. Payload WILL be exceeded before reaching your stated tow capacity. Check the sticker on your door jamb and check your gross vehicle rating. Google tells me this number is 5357 for a 2005 Venture. So the total weight of everything in it cannot exceed this weight.
Not sure what you mean by payload?? 🙂
Apr-19-2015 10:05 AM
Jetta03 wrote:dadmomh wrote:
Glad someone beat me to it re the frontal area. That makes all the difference in the world between 2100# of boat and 2100# of travel trailer. I am getting the feeling that the OP is looking for support in this decision and not finding it.
OP, please understand that folks on the forum have been around a long time, have seen or heard most and are only offering suggestions based on their knowledge. We may not be perfect, but usually pretty much right on with the opinions. If you have already made up your mind to go with this combo, we all wish you the best and safest travels. If you're after solid advice, please take it in the spirit it's intended.
One member often said, "I can pull my 23SS with my garden tractor, but it doesn't mean I should". Wisdom.
From your signature
2003 F-150 supercrew tow rating 7700lb
Rockwood 2604 gvwr 7714lb
Apr-19-2015 09:57 AM
From your signature
Apr-19-2015 09:34 AM
Apr-19-2015 08:58 AM
Apr-19-2015 06:10 AM
Apr-19-2015 06:01 AM
You really need to do some research and listen to what the experienced people here have to say.
Your payload will be listed on a sticker on your driver's side door pillar.
Bruce
On an '04, maybe not. I think the mandatory tire and safety sticker came around in '06 but it might have one.
It won't make any difference to the OP but "payload" and the payload rating are what the mfg. says the vehicle can carry (weight). This would be the weight of passengers and cargo inside the van, the weight of the WDH, and the tongue weight of the trailer.
Apr-19-2015 04:16 AM
Jetta03 wrote:
2004 chevy venture
curb weight 3699 (gvwr 5257, couldn't find gcvwr)
payload 1612lb
towing 3500lb
14 foot kz sportmen
gvwr 2800 (unloaded 2126)
hitch wt 323
I wouldn't push it too much, but you should be well within all your specs with this trailer. I think you'll find the minivan makes a very good tow vehicle.
Apr-18-2015 07:51 PM
