โOct-11-2014 08:20 AM
โOct-17-2014 05:25 PM
M GO BLUE wrote:Denny & Jami wrote:M GO BLUE wrote:
Will it tow it? YES
Will it tow it SAFELY? NO
You need more truck or less trailer...
You forgot to add In My Opinion
Denny
No I didn't...but thanks for asking
โOct-17-2014 03:27 PM
boobie41 wrote:
thinking of buying a solitude 320x 5th wheel, only have a ford f250 gas, 2015 pu, willthis do the job?
โOct-17-2014 03:26 PM
8iron wrote:Hybridhunter wrote:
Sure the 6.7 does it at lower RPM, but not a whole lot quicker, that was my point.
Exception being those who think full throttle is verboten.
And as a person who has owned both. I can say the extra 15 hp and 400 tq make my 6.7 considerably quicker getting up to speed. Especially when towing.
โOct-17-2014 02:25 PM
Will it tow it? YES
Denny
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
โOct-17-2014 12:39 PM
โOct-17-2014 05:38 AM
โOct-17-2014 05:01 AM
โOct-17-2014 04:55 AM
M GO BLUE wrote:
Will it tow it? YES
โOct-16-2014 08:43 PM
8iron wrote:Buck50HD wrote:
Finally did a couple 0-60 runs with our rig and it was 18 seconds. That was counting from the time the tach hit 1500RPM. From just starting to roll it was probably closer to 17. Towing 9000lb.
At low elevation, it's been proven that the gas trucks perform just as well as diesels, 0-60 or maintaining highway speeds. They just sound like they're working for it.
IB's recent comparison of the 6.4 hemi and Cummins demonstrates this very well. It did take a little more HP in gas form to match the diesel but if you wear ear plugs and put your foot in it, there's very little difference.
Link
While this test is a bit dated (Ford upped the HP &TQ for the 6.7 shortly after this was published) the 6.7 was still 3.5 seconds faster 0-60 than the 6.2.
โOct-16-2014 06:33 PM
โOct-16-2014 05:12 PM
โOct-16-2014 05:06 PM
โOct-16-2014 04:50 PM
โOct-16-2014 03:57 PM
bid_time wrote:wintersun wrote:BS
.... In many areas it is 200 feet or less from the cloverleaf on ramp to being on the highway ....
