โDec-11-2015 11:23 AM
โDec-27-2015 01:52 PM
bfast54 wrote:
Well I look at it this way since I'm the one paying the bill I do what I feel is best --if you're the one paying the bill then you do what you feel is best !!
Where I'm at in the north We can get two to three foot of snow on the roof of an RV and then in the spring when it rains that turns into wet snow ----ever try to pick up a shovel full of wet sloppy snow ???? weighs a lot doesn't it ???
imagine 30. Ft. Rv.. Wet. Snow. 2 feet high on top of the trailer-- I think that adds a pound or two
โDec-27-2015 01:16 PM
Rally's attended so far-21
โDec-17-2015 05:32 PM
temccarthy1 wrote:
So which is it now? I posted this same question on this forum a month ago and was advised by every responder that is was NOT necessary and not to do it. I called Keystone directly and they also said NOT to block it.... Now on this thread, I am seeing opposite opinions and now quotes from the tire manufactures ( mine are Carlisle) that say to BLOCK IT.. Jeez.... which is the right answer?
โDec-17-2015 02:59 PM
โDec-16-2015 07:31 PM
โDec-16-2015 08:15 AM
corvettekent wrote:Best advice or Florida or South Texas. Great place to store tires for the winter.:B
I just take mine to AZ for the winter.
โDec-16-2015 05:09 AM
Interesting the three different instructions on tire pressure... Carlisle, reduce pressure -- Maxxis, "adjust pressure" -- Goodyear, increase pressure.
Well, that doesn't help! lol!
โDec-16-2015 03:41 AM
โDec-16-2015 03:11 AM
JIMNLIN wrote:...and why is this necessary?
I'm open minded and just trying to learn...
Per Carlisle;
โ Keep trailer tires in a cool dry place and out of direct sunlight
during storage.
โ Use tire covers to protect tires from the harsh effects of direct
sunlight, moisture and temperature extremes.
โ During extended storage, use a thin piece of wood or other surface
barrier under tires to extend tire life. For seasonal or extreme long
term storage, elevate the trailer on blocks to take the weight off the
tires. Reduce the air pressure and cover the tires to protect them
from direct sunlight.
Per Maxxis;Tire Storage
Maxxis recommends storing tires indoors in a clean, cool and dry area away from UV rays or ozone gases (eg. generators). Tires should be stacked flat and reduced to 15 psi if mounted on wheels during storage.
If tires must be stored outdoors, Maxxis recommends raising tires off the storage surface to avoid excessive contact with the elements. If possible, wrap the tires in an opaque polyethylene cover to minimize the effects of ozone and oxygen.
If a trailer is being stored without removing the tires, place blocks under the trailer to remove all weight from the tires. Avoid moving the trailer during extreme cold weather.
Always adjust inflation pressure before putting tires back into service
Per Goodyear;Storing your vehicle properly helps protect your tires.
โข Keep your vehicle in a cool, dry storage area out of direct sunlight and UV rays.
โข Unload your vehicle so that minimum weight is on the tires.
โข Inflate your tires to recommended operation pressure plus 25%, but donโt exceed the rim
manufacturerโs inflation capacity.
โข Thoroughly clean your tires with soap and water before storing them to remove any oils that may have
accumulated from the road.
โข Move your vehicle at least every three months to help prevent cracking and flat-spotting,
but avoid moving it during extremely cold weather.
โข Place your vehicle on blocks to remove the weight from the tires. If the vehicle canโt be put on blocks,
make sure the storage surface is firm, clean, well-drained and reasonably level.
Now if anyone need to know why the tire makers recommend all this ...give them a 1-800.
My RV sits on 2" x 8" x 48" long on limestone crusher run in a trailer shed out of the sun. I keep LT tires on my trailers at max pressures 24/7. I change them out at 7-8 years and 50k-55k miles as their getting close to the wear bars.
IMO the best idea is keep them dry and out of the sun when sitting for several months.
โDec-16-2015 12:11 AM
mordecai81 wrote:
I understand about not jacking up under the axle tubes, but putting blocks under the frame must be o.k.. Or is their something I'm not getting about this?
โDec-15-2015 06:28 PM
Campfire Time wrote:
Most don't. I don't. And you have to be careful. If you have Dexter torsion axles you can't jack them up or put blocks under the axle itself otherwise you'll damage it.
I park on a gravel pad and have 2 in boards under the tires so it doesn't sink in the spring when the ground is wet.
โDec-11-2015 06:33 PM
โDec-11-2015 05:34 PM
โDec-11-2015 05:31 PM
