โJan-14-2021 10:02 AM
โJan-17-2021 09:08 AM
Cummins12V98 wrote:Grit dog wrote:Cummins12V98 wrote:
YEP, a 1500 can tow it but can it "HANDLE" it in unforeseen conditions.
How is it less safe to pull a (the OP) 9-10klb trailer with a 6000lb+ truck rated to tow 11k,
than pulling almost 30k with a 8000lb + truck rated to tow almost 30k?
Seems like you are both at roughly the same % of max capacity...
I am talking windy conditions and evasive maneuvers. Length matters in both.
โJan-17-2021 09:05 AM
dodge guy wrote:
I`m waiting for the 4500/5500 guys to show up and say how dangerous it is to tow anything with the puny 3500 dually! LOL
a properly equipped 1500 at ???? % of max capacity is just as safe as a 2500/3500 at the same ???? % of max capacity.
โJan-17-2021 09:01 AM
โJan-17-2021 08:59 AM
So, I drove a 15,000 lb(mostly aluminum) Class 8 Chevy Titan 90 tractor with 65,000 lbs of aluminum trailer and gasoline(8500 gallons) behind it. Was that an unsafe combination? The tractor was twin screw with heavy duty components and tires. 150/1500 can not be counted as heavy duty compared to their bigger brother 250,2500 and 350,3500's. Having the right tool for the job has always been important when stuff happens.
โJan-17-2021 08:55 AM
Two major differences.
#1 Cummins12v98 is towing a 5th wheel which is 100% more stable than a TT in cross winds and not affected by semi's bow waves.
#2 He also has four tires under the hitch, six total.
โJan-17-2021 08:52 AM
Huntindog wrote:Grit dog wrote:How many 30,000# TTs are out there?Cummins12V98 wrote:
AFAIK, the only way to approach that weight is with a flatbed loaded with bricks, concrete etc... Such loads do not have the large sidewalls that TTs do, making them a more stable tow
โJan-17-2021 07:32 AM
โJan-17-2021 07:29 AM
โJan-17-2021 07:26 AM
โJan-17-2021 07:23 AM
โJan-17-2021 05:36 AM
โJan-17-2021 04:45 AM
โJan-17-2021 04:17 AM
โJan-17-2021 12:16 AM
โJan-16-2021 06:59 PM
