May-18-2015 12:21 PM
May-21-2015 11:10 PM
May-19-2015 03:56 AM
May-18-2015 07:51 PM
May-18-2015 04:49 PM
cbshoestring wrote:
I do NOT think you will get much debate, adding a cooler will be wise. Check your local auto parts store, adding a tranny cooler is normally a pretty easy DIY adventure.
Of course, you will get the debate on whether or not it should be run seperate of the exiting cooler, or in conjunction with the existing. :B BEFORE or AFTER :h
I go with "in Conjunction". I also prefer adding the new cooler BEFORE the existing one in the radiator. This "Helps" the existing, while still allowing the existing to do its job. Up here in the colder states, we need that warm fluid in winter time.
May-18-2015 03:58 PM
May-18-2015 03:50 PM
lbrjet wrote:path1 wrote:
(edited to reflect OP edit)
Our class C with a 5.4 leaves our driveway at 10,380 pounds. It's a 2003 and we have lots of mountains we go over. My trans gauge hardly moves on our hottest days going up steep grades at freeway speeds. My gauge barley moves going up steep logging roads at real slow speeds. The cooler is stock, so no need to go for a monster size like 6.0's have.
Also when doing the install I would also put in one of these. http://puredieselpower.com/manufacturer/magnefine-2 and NAPA has their own brand also (same thing just painted different).
There's probably more info with spec's that can be found on-line.
Just because the Ford idiot gauge is not moving doesn't mean the tranny isn't getting hot. Mine tranny gauge doesn't budge until 235 degrees. That's why I have a Scangauge. I want to know if if breaks 200, not 235.
May-18-2015 03:46 PM
May-18-2015 02:07 PM
May-18-2015 01:31 PM
May-18-2015 01:12 PM
May-18-2015 01:08 PM
May-18-2015 01:05 PM
May-18-2015 01:01 PM
dockmasterdave wrote:
You probably want to pick up an extra few feet of hose. They seem to cut it pretty close from the warehouse.
May-18-2015 12:55 PM
