JRscooby wrote:
Why on earth do you think you need to richard around with WDH on a ton truck?
Because of all of the fear spread around like bovine material blindly following the fear mongers like a bunch of wimpy and mindless "lemmings" on this forum and many other forums like this one.
Fear like "your gonna kill someone" if you do not use WD..
Fear like it is a "required safety item".
Fear like "your gonna overload your vehicle".
Fear like you "you will have sway without WD".
Fear like "you won't like the ride without WD".
Not EVERY TV and trailer combo "needs" WD and when you buy up to the "big boys" platform WD really becomes less of a help and some cases may result in a poor handling situation.
WD was originally designed to to help folks tow much heavier trailers than what their vehicle would have been capable if solely relying on only the capacity of the rear axle..
There is no law anywhere which states one MUST use WD, it is up to the owner of said combination to determine IF it is needed.
Got enough cargo capacity, enough front and rear axle capacity, not much reduction of the front axle, you might be a candidate to try a test tow without WD.
As long as you keep 13%-15% weight on the trailer tongue AND you have a TV that is very capable it will tow stable.
And for the record, I do not have a "1 ton", nope, do have 3/4 ton and I have about 3500 lbs of available cargo weight on my TV and a 26ft TT with just under 950 lbs fully loaded.. No, I do not use WD.
No, have not died, have not killed anyone, have not been in an accident, have not had issues with sway and it is a rather comfortable tow.
I have had to make several major avoidance maneuvers over the years which required stomping on the brakes while cruising at 70 MPH to avoid deer that ran out in front of me.. Kept complete control of the entire rig the entire time avoiding the deer, avoiding fellow motorists and never went off the road or crossed lines in the process..
Don't think the outcome would have been good if I was relying on a lighter vehicle and WD.. I will take the heavier vehicle..
