Trip report:Kayaks, TCs and Fish on deck
Buzzcut1
Nomad II
Nomad II
It would seem that whenever I get a new toy I go whole hog and jump right into the deep end. A few weeks back I bought a new sit on top Kayak and I have spend most of my free time getting it set up and going fishing at the local lakes just putting it on top of the Volvo. It turns out that it was probably good that I did that as I learned how to really secure it to the cross bars. My friend Pat screwed a deck cleat into the roof of his lance to which he hooked in a bow line, I decided that I do not like the idea of more holes and possible roof leaks so I investigated alternatives on the net.
I hauled the kayak up with a knotted rope ( note always have TC on the truck and the jacks extended and touching the ground for stability while doing this) It only took 10 minutes to get the Kayak lashed down to the Thule cross bars with ratchet straps ( snug not tight) then you take the tails of the straps and drop them through the scupper holes and tie them to the rack cross bar as a back up in case of mechanical failure
I also used one ratchet over the kayaks bow forward of the cross bars to hold the nose down to remove any excess lift stress on the crossbar tower to rail spring loaded interface
The furry kids assumed their usual riding positions
then Kozmo decided to join big brother Jake riding shotgun. Watson stayed in the back snoozing
I stopped at Bass Pro to pick up a set of scupper mounted wheels to haul the kayak to the water. figured $60 was better that throwing my back out carrying it.
Campsite is perfect. in the overflow dirt lot, dry camping no one within 300 yards
Lake is beautiful
Landed 3 of these guys tonight using a #14 woolybugger on a 6x tippet
http://youtu.be/EZ7FoYm52_M
Dinner was good, Cajun spiced Fish and a salad
Good company
Exhausted after two 3 hour fishing/kayaking sessions I passed out at 9pm
At 5:45 am I awoke to a beautiful sunrise over the Sierras while letting the dogs run loose and do their business
camp at sunrise
then it was time to carbo load then go do some more fishing
The Bluegill were biting I got two with the wooly bugger then noticed that something was hitting the yellow foam indicator on the leader so I switched to a small yellow bass popper and caught two more before the wind kicked up something awful and I decided to head for shore and call it a day
morning fishing video
http://youtu.be/MEMDMeeL1pA
I think I tuckerd ol jake out
Last look at the lake
Me, the dogs, a tc, Kayak, fishing, good food and Beer. perfect weekend. And to be perfectly honest I never knew that Bluegill were so dang fun to catch. These were the very first ones I ever caught.
There was a high wind warning on the Altamont Pass of I580 and the message sign said to reduce speed so I stayed in the far right and putted up at 45 and still got buffeted fairly hard
Now did anyone get the number of the truck what hit me? I am totally worked. Still have to take they Yak off the roof and sweep out the tc.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
13 REPLIES 13
iwon415
Great TR, Buzz!
dakonthemountai
Yay! What fun!! I love how you grab the fun when you can!..... dogs, TC, fishing, beer, (or a frosty martini in a plastic glass for me! ๐Ÿ™‚ )
Dak
2018 GMC Denali "Extreme" and 23' EVO 2050T Travel Trailer
Escapee member #224325-Since 1992
billyray50
Buzzcut1, Great trip report again!!
Redsky
RVkayaks.com makes a couple different kayak racks that hold them behind the truck vertically. DOT regs limit the height of a vehicle to 13'6" so that means a 12' or shorter kayak for the racks to work. I recently bought a Trident 11'5" kayak for fishing. They have a swing away version so you can have a rack with two kayaks and two bicycles and have access to the rear of the camper.
With the drought and so much water shipped from northern CA south to the corporate farmers (aren't government subsidies great) many of the boat launch ramps are closed for the foreseeable future and many reservoirs closed to all boating so I am switching to kayaks and to doing more ocean fishing.
Buzzcut1
Nomad II
Nomad II
oy, getting older bites. every muscle in my body had a bit of lactic acid burn going for most of the day.
Couple of things in retrospect. Sunscreen and shorts , if you are out long enough even repeated applications of SPF50 will not keep your legs from a bad sunburn but nice lightweight nylon SPF50 pants and socks over the feet will.
You can never have too much cold beer
Never underestimate the joy of disconnecting yourself from the elctronic tether, turn off the cellphone toss it in the dry bag in the hull for emergencies and leave it that way until you are ready to go home.
After a good day of fishing nothing beats a couple of cold beers while leaned up against a tree with your dogs as your only companions unless of course your wife is with you, but she has to have her own damn beers ๐Ÿ™‚
Bonesquatch
I have a 16' Tarpon and use it about every weekend. Do you have an anchor trolley set up yet? They make life tons easier when you want to sit for awhile and maybe adjust your position easily. Also a rudder will be the best investment you'll ever make for your yak. Hands free steering and a whole lot better maneuverability. Great rig you've got and it looks like a perfect weekend. Great writeup too.
"That's just...like...your opinion...man..."--The Dude
2012 Chevy 2500 HD
2012 Lance 850
Buzzcut1
Nomad II
Nomad II
dadwolf2 wrote:
Buzz, have you looked at Austin canoe & kayak for hard to find gear? I've had good luck with them in the past.
Oh I have the rigging from my climbing days, stopped at bass pro on the way home for an anchor. Just have to set it up. Used one of my heavy rubber wheel chocks and some nylon cord to improvise on this trip
dadwolf2
2005 Dodge Ram 2500 CTD,4X4,NV5600
2014 Adventurer 86FB
Buzzcut1
Nomad II
Nomad II
need to rig up a bow anchor pulley system for the next trip
Bonesquatch
Looks like you're living right. Well done!
2012 Chevy 2500 HD
2012 Lance 850
Targa
It doesn't get much better than that !!
pa_traveler
One of my favorite types of fishing,is flyfishing with poppers for panfish.
TucsonJim
Dang you. Now I have to plan a fishing trip. Nice bluegill. That sure looks like fun.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
