โMar-17-2016 01:19 PM
โMar-19-2016 06:54 AM
โMar-18-2016 04:05 PM
Bud
USAF Retired
Pace Arrow
โMar-18-2016 04:03 PM
โMar-18-2016 03:51 PM
enblethen wrote:
Batteries should be marked positive and negative with the symbols either "-" for negative and "+" for positive. The cables and wires coming off the batteries should be marked. Normal way is to use electrical marking tape. Red for positive and Black for negative with in six inches of connection.
โMar-18-2016 08:02 AM
Bud
USAF Retired
Pace Arrow
โMar-18-2016 07:43 AM
โMar-18-2016 06:51 AM
โMar-18-2016 06:35 AM
enblethen wrote:
Make and model of refer would help.
Since it is getting power to the display panel the refer is getting power.
Disconnected from shore power.
Disconnect battery.
Locate the battery fuse in the 12 Volt DC panel.
Connect battery up.
Use volt meter to check for 12 volts DC to bat fuse holder.
No power? Check fuse or circuit breaker near the battery. Could be in battery box, along frame rail under front of trailer or in junction box where the Battery cable, umbilical cord and trailer wiring comes together.
Another way disconnect from shore power.
Disconnect battery.
Plug into shore power. Check for 12 volts DC in 12 power distribution panel.
No power. Replace or test, do not look, at reverse polarity fuses.
Post make and model of converter.
โMar-17-2016 04:18 PM
โMar-17-2016 03:49 PM
โMar-17-2016 03:23 PM
โMar-17-2016 03:22 PM
Bud
USAF Retired
Pace Arrow
โMar-17-2016 03:17 PM
โMar-17-2016 01:58 PM
โMar-17-2016 01:41 PM
SoundGuy wrote:
I would have thought that a relatively new rig such as yours would have a converter with a reverse polarity fuse, the purpose of which is to blow if you inadvertently hook the battery up backwards. If so though I would have thought you'd have no 12 vdc power at all ... nonetheless, have you checked for a blown reverse polarity fuse? :@
