Jan-25-2016 06:28 AM
May-21-2016 05:50 AM
May-21-2016 05:24 AM
IDoMyOwnStunts wrote:brulaz wrote:2016 Ram Manual, p290 wrote:
If the gross trailer weight is 5,000 lbs (2 267 kg) or more, it is mandatory to use a weight-distributing hitch to ensure stable handling of your vehicle.
That's from an online version of the 2016 manual (Version 3) I downloaded. Trouble is, it's very generic. Used for ALL Rams, 1500s, Vans as well as 2500 and 3500s.
*sigh*
Not sure where you got that. That is NOT what my manual says.
"If the gross trailer weight is 5,000 lbs (2 267 kg) or more, it is recommended to use a weight-distributing hitch to ensure stable handling of your vehicle."
May-20-2016 06:02 PM
May-19-2016 07:57 AM
May-18-2016 08:28 AM
IDoMyOwnStunts wrote:TomG2 wrote:
What does Ram have to say on the subject? A similar Silverado 2500HD does not require WD for the trailer you are towing and experience proves GM to be correct.
Read my post above. From the manual on page 689, Ram recommends a WD hitch for trailers over 5000 lbs.
May-18-2016 07:52 AM
May-18-2016 05:15 AM
May-18-2016 04:52 AM
May-17-2016 09:17 PM
May-17-2016 08:46 PM
May-17-2016 02:24 PM
May-17-2016 05:43 AM
mudfuel07 wrote:
Look at Harbor Freight for a reasonably priced WD hitch. I use one on my trailer and have no issues. You can get a coupon too.
May-16-2016 06:56 PM
hbrady wrote:
So I was checking out my hitch receiver last night and it's a class V with 2.5'' opening. All my hitches and my buddy's WD hitch (I borrow) are all 2''. Looks like another expense 😞
May-16-2016 03:04 PM
hbrady wrote:Can you get by without a WD hitch, you bet. Would I? No way, the ride and handling are so much better with a properly set up WD hitch.camp-n-family wrote:
I hope you have better experiences than me. Report back and let us know how it goes, maybe there's a problem with my truck.
OK, I had my 1st loaded tow, about 15 miles with some good long hills. I was lazy and did not set up my WD bars so I towed without them. Truck did fine, I loaded the front pretty heavy (4 cinder blocks in front pass through, 3 cases drinking water under bed in front). I had no sway issues at all, I did however experience some surging / bucking a few times but I imagine that will improve when I get WD set up.
My weight (based on yellow sticker and what I had loaded) was probably around 6200 lbs. I had to get into the Hemi on the hills but I was able to accelerate and pass slower vehicles. At one point going up a rather long steep hill I passed a semi and realized I was doing about 65 and had to back off. Gas millage was only 9 but most of the drive was hills.
All in all, I'm happy.
