Dec-02-2020 09:50 AM
Dec-05-2020 02:00 PM
IdaD wrote:As a blanket statement, this can be false.
Just my two cents but having one of the big diesels hanging over the front axle goes a long way to eliminating the need for weight distribution. Will 1400 lbs reduce the the front axle weight on that truck? Sure. Enough to matter...eh, not so sure. Even loaded up you still have more weight on the front axle than an empty gas version of the same truck does.
I'd at least try it out before you go spend money.
Dec-04-2020 04:26 AM
Dec-03-2020 02:53 PM
Dec-03-2020 10:07 AM
Sjm9911 wrote:
See what your manual recomends. Mine has it listed. And the factory sway control is not the same as sway control on the TV. The sway controll bars help you to control sway before it happens. The TV one kicks in after it detects sway. I much rather have it controlled then ajusted for afterwards.
Dec-03-2020 09:47 AM
Dec-03-2020 08:37 AM
Dec-03-2020 07:59 AM
Dec-03-2020 06:44 AM
So my thoughts are to drop it on the ball and try it... Am I nuts?
Dec-03-2020 04:29 AM
Dec-02-2020 09:21 PM
Dec-02-2020 09:08 PM
Dec-02-2020 08:37 PM
Dec-02-2020 05:29 PM
Dec-02-2020 04:48 PM
