Who all is into performance mods on their TV ?
jcain
I'm one that can't leave well enough alone regarding vehicle performance. I can't be the only one around here... What have you all done ? This rig is pretty modest so far.
2014 Avalanche 355rk
2016 F350 CC-DRW Fx4, Tow Boss, Monochromatic King Ranch,Fox 2.0, Pmf Fox 2.0 DSS, OUO ALA, OUO spring thing, OUO traction blocks & bars, AL 5000 ultimate + wireless one, AMP steps,Projectors, Rigid d2 fog lights and 30"sr light bar.
36 REPLIES 36
Grit_dog
Navigator
Navigator
You're on the wrong site for that. Several of us but we're in the minority around here.
Too much geritol, not enough red bull!
Grit_dog
Navigator
Navigator
06Fargo wrote:
Equipped the 1 ton with rear air suspension, pyrometer, manifold pressure gauges, mild tow tuner... it still needs better brakes, parking brake (it's manual trans), slower reverse in 2wd (2wd low switch kit not available for this model)
Next big mod will be the KW mod: Clicky
^That is pure awesomeness!
BB_TX
Truck has plenty of power. Not going to do anything that might impact warranty on that expensive engine.
Triker33
Toad Dyno 355HP 380 ft lb
160 Hi Performance thermostat, Catted down pipes, 3-Bar Map and Tuner for Stock/91 Octane/93 Octane, Airaid air cleaner and Dynomax muffler
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
4x4ord
Mud flaps, B&W hitch and weather tech floor mats
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
noteven
Chuck_thehammer
Corvette is done, 500 hp from a 383 cubic inch, a 1979.
motorcycle ... 120 hp from 110 cubic inch and 700 pounds.
Truck, nothing to the engine.. truck/motorcycle/30 foot travel trailer is 17,000 pounds rolling.. need dependability.
