Why not a 2 speed or quick change rear end option
Taco
I was just day dreaming today while celebrating at the inlaws and was wondering why no truck maker offers a 2 speed rear end or a "quick change" like the race cars use, rear end option.
You would think it could give the best of both worlds better mpg and better towing/hauling power. With a quick change you could tailor the output of you truck to the anticipated terrain and the weight of the trailer.
37 REPLIES 37
Bedlam
Moderator
Moderator
Many of the off road side by side vehicles do not use a transfer case. The use a primary transmission driving two dual-speed differentials (that may also have the ability to disengage or fully lock up).
The ones coming of China use a mini car engine with a locked manual transaxle (no differential). The engine and transmission sit longitudinally and each transaxle output drives a shaft to the axle differentials.
This is not much different than what you are asking for except the ratios are for high and low range instead of tow and economy.
06Fargo wrote:
At the risk of taking a rashin' - this is a great idea - gear reduction as close as possible to the wheel ends gives the greatest benefit in pulling power vs more transmission speeds < overdrive.
My dune buggy is based off a 1200cc VW Bus engine and chassis it uses gear reduction units at the hubs to allow a small engine move a large vehicle. The dune buggy is much lighter than the Bus, but the gearing allows it to have 33" rear tires with out bogging out in sand.
monkey44
Nomad II
Nomad II
I recall our old farm truck - the dump - had dual-position RE, and we had a shift lever (like the standard 4x4 lever) above the 'drive hump' ... we could shift into a very low 'grunt gear' in the RE and really get some pull-power when loaded and towing a tractor uphill. It was not a big deal to shift back and forth, although the lower gear was really low and non-syncro, so we had to stop dead to shift into or out. But once into one or the other, the gear shifting acted like any other tranny ... first through fourth, in the old GMC two-ton, with the 'granny gear' first.
As simple as it was, I can see technology easily re-creating that gear-transfer into a synchro-tranny with higher gears that could shift-on-the-fly and put what is now a four or five speed drive train into a ten or twelve speed drive train. I know, a lot of shifting, but if you think it through, once you get into one or the other, it's actually still shifting from first - fifth anyway.
I'm just as sure (for enough money) the automakers can build a auto tranny that will do it too. That means ONE gear shift gives five gear ratios each. Instead of ten or twelve gear combinations. I'm no engineer, so can't even begin to draw this out, but in my brain, it worked well on the farm for power, so I can imagine it can't work in reverse for more mileage.
Probably similar to the 'low range' vs 'high range' in the electronic 4x4 today, except instead of a power gain, it would become a mileage gain.
Probably not been into the minds of the auto-engineers until now as the price of fuel gets everyone's attention, and mileage becomes a more important factor in new truck purchase than what was once the power side of the advertising and use potential in a HD pick-up truck.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
carringb
Wes Tausend wrote:
Thanks for the reinforcement. I did do some preliminary looking but it was inconclusive, especially shift points and holding a selected gear. I guess I would trust Banks Power over and above unfamiliar products, whatever features they may offer.
The power seems ok for the TT, but a little more couldn't hurt, maybe at least match the V-10 hp. There is probably not much sense keeping it stock as the untouched noisy old 7.3 rapidly ages beyond current populararity during my ownership.
I wonder if computer shift points wouldn't be even further off with a Gear Vendors.
Wes
You can add a simple TCC lockup override. It's just a matter finding the correct wire to tap in the transmission harness.
I added both the Banks Transcommand and Predator tuner to mine. The Banks allows earlier T/C lockup. It will even lockup in 1st under heavy throttle. (I'm not sure the diesel programming allows that however). I've also reduce my OD shift point which allows me to climb 10% grades in OD as low as 40 MPH, turning barely 1200 RPM.
2014 ORV really big trailer
2015 Ford Focus ST
noteven
Wes_Tausend
bmanning wrote:
Wes Tausend wrote:
I'd be satisfied with the ability to force an earlier shift, and lock-up, on the 4R100 auto on our 2000 F-250 7.3L. As it is, it does not shift to OD, nor converter lock-up, until about 40 mph even when there is virtually no load. If I had a manual, I'd be short-shifting around town while running empty.
Wes
There at least used to be (likely still are) products on the market that can allow the driver to dictate TC lockup. Maybe Banks Trans Command, something like that? Can't speak to their cost or quality but they do exist.
When I had my 2002 7.3L I always had a feeling that the stock 4R100 left some performance on the table and if I'd have kept it a built trans would've definitely been in the plans.
Wes
Days spent camping are not subtracted from one's total.
- 2019 Leprechaun 311FS Class C
- Linda, Wes and Quincy the Standard Brown Poodle
MX-RV
So your jeep still has a "transfer case" it's just built into a transaxle mounted directly to the engine. If you look on the video the front drive shafts come directly from the transaxle as does the "prop shaft" as he calls it.
I'm impressed to see its a 9 speed. I'd like to see the 2500's 250's come with 9 or 12 speeds. Weighted at the bottom for torq and at the top for highway miledge. I saw a you tube vid once of a f350 the guy had remade the bell housing on a freight liner 16 or 18s it wa pretty sweet. Mind you he did a no throttle take off from a stop in 4th if I recall. Maybe for most uses around here that's a little low. I'm willing to bet he's not got much more top end than the stock was.
You can take me camping, but apparently you can't make me camp!:S
bmanning
Wes
BManning
baking in Phoenix :C
-2007 Volvo XC90 AWD V8
4.4L 311/325 V8 6sp Aisin loaded
6100lb GVW 5000lb tow
-1999 Land Cruiser
4.7L 230/320 V8 4sp A343 loaded
6860 GVW 6500lb tow
RV'less at the moment
ib516
Sorry for the off topic...
It has a 2 speed front and rear axle, each with the same regular, and 2.92:1 ratio in each diff. The rear also has an e-locker, and it has a 9 speed auto trans. Complex system.
My point was that the technology is there to have 2 speed axles in tow vehicles, and I don't think that it will be long before your 2500 and 3500s have the same technology.
Start around 4:30 in This video
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
Wes_Tausend
Wes
jauguston
Do you have both 4 high and 4 low?
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
B_O__Plenty
ib516 wrote:
My new jeep cherokee trailhawk has a 2 speed rear axle...no transfer case, but 4 low. The way they achieve that is by having a 2 speed (with locker) rear axle. It is possible.
If they use 2 speeds in the rear axle..then how do they change the ratio in the front axle to get 4 lo if they don't use a transfer case?? I'm confused.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
rjstractor
I looked at the website and tried to figure out how that is possible. Don't see how you could have high and low range 4wd AND a neutral position for towing without a transfer case of some sort. Possibly the Active Drive 1 system (high range only)has no transfer case and the Active Drive 2 has a more conventional high and low range transfer case. The website doesn't really explain how they work.
2017 VW Golf Alltrack
2000 Ford F250 7.3
coolbreeze01
The Jeep Systems are interesting.
2008 Ram 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2014 Sandsport 26FBSL
jauguston
I assume that you then can have four wheel drive in one range only otherwise there would be a ratio mismatch between front and rear axle ratios. Way off topic I know (-:
Pressure Pro TPMS
