Oct-19-2014 03:27 PM
Oct-20-2014 02:58 PM
DWeikert wrote:Arctic Fox does not say not to use the camper off of the truck. The post was regarding storage recommendations. We take the 1140 off all the time - launching the boat, sightseeing, etc. Sorry for the confusion.
Like the Arctic Fox example Gripnriprod posted, some campers are not designed to be used off the truck. I don't know which campers are or aren't like this but I do know my Northstar is meant to be used whether on the truck or on the jacks. So I store on the jacks with the camper lowered as close to ground as the jacks allow, with the front a little high for runoff.
Oct-20-2014 02:56 PM
Oct-20-2014 02:27 PM
Oct-20-2014 01:44 PM
Oct-20-2014 01:37 PM
Oct-20-2014 01:26 PM
wsdepa wrote:
I also have often seen people camping with the jacks extended down to the ground while on the truck. I don't know why they do this, mine doesn't rock very much no what I am doing inside and the risk of forgetting and driving off thereby destroying the camper is present.
Oct-20-2014 01:04 PM
Oct-20-2014 12:45 PM
Oct-20-2014 12:43 PM
ajcal225 wrote:
In my case, I'm not talking about 'at home', so to have that extra insurance, i'd have to pack whatever stands I keep my camper on at home (in my case, it sits on 3 heavy 10x10x6' beams) into the camper to take them with it.
Oct-20-2014 11:00 AM
wintersun wrote:
Lance recommends not using camper stands but to use only the jacks when storing the camper. RV parks are required by law in most states to allow only the use of the jack stands and to have the camper no more than 12 inches above the ground level when it is off the truck.
Oct-20-2014 10:57 AM
mkirsch wrote:
What baffles me is why someone would NOT be able to see the potential problems, and NOT want to have a little insurance against them.
Maybe nothing bad will ever happen. Maybe your camper will never leak and rot. Maybe a big wind storm won't come through and test your jacks. Maybe your jacks won't have a random structural failure. Maybe the ground won't soften and give way under the camper.
Nothing wrong with a bit of precaution, especially when it's so simple and cheap.
Oct-20-2014 10:53 AM
Gripnriprod wrote:
Arctic Fox says this under the heading of outdoor winter storage:
"Always support the camper at the corners and outside walls. IMPORTANT: You must support camper correctly as set out in the diagram (Page 21A). Incorrect placement of blocking will result in damage to the sub floor and/or waste and fresh water tanks."
For some reason the diagram referred to does not show up in the online Owner's Manual but according to my hard copy, they suggest stacking 2x6's until you have enough height to lower the TC until the jacks don't touch. They are to be placed running side to side at the front of the bottom, again in the middle and again 8' from the front. As I recall, I stacked 10 - 2x6 x 6' for a total of 15". I nailed them together and attached some straps to make them easier to move around.
Oct-20-2014 10:44 AM
Oct-20-2014 05:33 AM
