The gearing on both will make the biggest difference. It won't be a powerhouse, but I expect the 5.4 will be fine in Tow-haul mode. Worst case, you can improve the power by relatively simple mods like K&N air filter and more free flowing catalytic converters, mufflers, and exhaust pipes.
BTW, I towed a 6000 lb trailer over the Cascades for a while with a '97 5.4 Expedition. My guess is the overall weight should be about the same although the 2008 5.4 should be more powerful by quite a bit.
