โApr-02-2019 06:52 AM
โJan-26-2024 03:03 PM
I know this is an old post, but I wanted to update this as I have found a company that will make a camera harness so you can relocate where you have the tailgate camera connection.
https://harnessdr.com/product/2016-2019-silverado-sierra-reverse-camera-extension-harness-36/
A couple of pictures of mine:
โApr-04-2019 05:26 AM
โApr-03-2019 05:50 PM
Bradymydog wrote:
On my 2018 GMC 3500 SRW, Denali, the camera wire/locking tailgate plug is located between the spare tire and the factory trailer hitch. It's tight to get at without lowering the spare tire. There is a red sliding plastic locking tab which secures the plug. Slide the red locking tab away from the plug (about 3/8") with your finger nail or screwdriver but do not remove it. The tab on the plug can be depressed and the plug will separate. I plan on making or buying a short extension so that I can pull the plug through the opening in the body and unplug it without crawling under the truck. Also on my truck the support/stop cables are retained by a shoulder bolt which must be removed in order to remove the tailgate as opposed to the spring device on previous models.
โApr-03-2019 05:22 PM
โApr-03-2019 02:46 PM
โApr-03-2019 01:05 PM
โApr-03-2019 07:04 AM
โApr-03-2019 05:22 AM
Kayteg1 wrote:
Ford supplied me with plugs to put into disconnected wires to protect them from dirt.
Check if Dodge has those too.
I have to go under the bumper to disconnect.
โApr-02-2019 08:20 PM
hedge wrote:
well since it seems to be going a bit off the rails I'll do my part. When I took mine off the first time (2017 F350) I got the wires disconnected fine but then realized I couldn't open it without the connection. Had to re-connect it to release the tailgate and start over. Yours may be the same.
โApr-02-2019 08:05 PM
โApr-02-2019 07:29 PM
โApr-02-2019 07:06 PM
On my 2015, I followed the camera cable up to an electrical box under the bed, on the plug there is a red lock tab that you slide back, then depress the tab on the plug and it should disconnect. There is a dummy plug stored next to the camera plug that you use to protect the open connection. Good luck.
โApr-02-2019 06:45 PM
โApr-02-2019 06:43 PM
GeoBoy wrote:jimh425 wrote:
Wow, OP asks about a new one and gets a comment about a 2015. ๐
Like I said.....
