โFeb-05-2019 10:00 AM
โFeb-21-2022 05:31 PM
LittleBill wrote:I have nothing to reference or measure. I do not own this type of water fill. Besides, you're having fun doing it
how come your not designing this?
โFeb-21-2022 05:27 PM
2112 wrote:
THIS may or may not help
โFeb-21-2022 05:24 PM
โFeb-21-2022 04:53 PM
2112 wrote:
Just read up of Fusion 360. First create an offset plane then use that as a reference for an angle plane. Offset plane sets the reference offset, angle plane sets the angle, build on the angle plane.
โFeb-21-2022 03:27 PM
โFeb-21-2022 03:15 PM
LittleBill wrote:
The problem right now, is I don't know how to make the ramp yet. Once I learn how to do it, it should work fine.
I will provide an update once I figure this out.
โFeb-21-2022 02:12 PM
K_and_I wrote:
I wish I knew correct terminology, it would make a response much easier. I tried the one 2112 showed above, but it wouldn't work on my fill hatch without modification. My camper uses a hatch that looks like this one:
Clicky
Taking material off of the portion labeled in red didn't help. I finally chalked the locking portion of the hatch on the camper and put the adapter against it. It appeared that the locking flange on the adapter was too close to the cap of the adapter (sorry again for poor terminology). I took a brass wire brush in a dremel and removed some of the inside of the locking flange, and was able to get it to go on. I can't test it yet as it is too cold here to be dealing with water and hoses, but I think it's going to work.
โFeb-21-2022 11:43 AM
โFeb-21-2022 09:57 AM
โFeb-16-2022 06:35 PM
โFeb-16-2022 06:10 PM
NMDriver2 wrote:
I use a cut off piece of garden hose about 1 ft long with the female end to screw onto a regular male hose end. I just put the cut end in the fill tube all the way to the connection and it has never come out under pressure. BTW I am pushing 80-90 psi through my hose.
โFeb-16-2022 05:08 AM
Bobbo wrote:
If it is now coming with a quick connect built in, I am glad I bought mine before the change. FWIW, I used it today for the very first time. Worked like a champ.
โFeb-16-2022 01:52 AM
โFeb-16-2022 12:40 AM
K_and_I wrote:PM me your mailing address and I'll see what it takes to mail this one to you. You'll have to whittle on it to get it to fit right.
So, are you interested in printing one for me?;)
