5th Wheel rear hitch
2001chevyturk
I am planning on fabricating a hitch for the back of our 5th Wheel. It will be primarily for bikes but may use for other things depending on what plans I find. Have used the 2" receiver that bolts to the bumper before but I am looking to make something a little stronger as I know the bumper is not strong enough.
Have thought of fabricating a hitch to fit to the frame and use a swagman bike hitch. Have also looked at campers with the cargo rack that flip up. Does anyone have any links or photos of hitches/racks that they have added to their campers. Thanks for any ideas!!!
2013 Sandpiper 365saq
2001 Chevy 3500 DRW
13 REPLIES 13
packnrat
sorry no photos right now. a bit raining outside.
but i had a two in receiver mounted to the frame of my 2001 sunny brook fifth wheel.
think over kill here. but i use mine to pull a second trailer with a cj-7 on it.
but using at least 120 wall plate steel. make a plate for each side frame rail. using at least 6 or 7 1/2-3/4 in bolts each side to hold it together. make the plates at least 3 feet long.
(spreads any and all stresses out).
cross frame 120 wall 2 in (square or round).
cross frame at least three places (four best) to prevent flexing of a side twisting of the frame. best if 2 in square tubing. (easier to attach the receiver tubing).
add a triangle bracket from the rearmost part of the receiver. out -forward to the front of this assembly. (stress thing again).
gusset everything.
add wiring as needed for towing trailer.
i use a surge brake flatbed (would love a electric brake unit) so not wired for electric brakes..for now.
for just a bicycle rack not as much needed. but DO NOT use the factory rear bumper storage thingy. as it will fail.
amazing it can hold a spare tire.
2006 F250 4X4 auto 6.0 short bed
2001 sunnybrook 24 ft
1984 cj7 built up a bit
kg6tgu
never too many toys, just not enought room to keep them
one dog who belives she is the master. rip 12 12 2007
12 loving years and loyal to the end.
just out having fun
2001chevyturk
Thank you for all the photos and advice!
2001 Chevy 3500 DRW
richardcoxid
Contact your 5w Mfg. and see if they mfg a โ€œbolt onโ€ hitch for your RV.
Hitchhiker stocks a hitch with a 2โ€ sq receiver that โ€œbolts onโ€ to the mounting pads welded to the 5w frame. Complete with mounting bolts for about $250. I know I bought one for my HH 5w, then i made a rack to mount my Honda Gen to.
Maybe it could be adapted for other brands.
2017 GMC Denali 3500 4x4 Duramax
2019 Outdoor RV (ORV) Timber Ridge 24RKS
Martyn
This is my hitch showing a bike rack on it. Fabricated and installed by a good welding shop.
And this was the reason I had it installed ๐Ÿ™‚ :
2020 Keystone Cougar Half-Ton 27SGS;
2019 Dodge Ram 2500 QC 4x4 6.4 Hemi BigHorn;
DEMCO Autoslide; 2 Honda EU2000i's;
Our Website
Looks like a simple piece of 4 square 1/4 or 3/8 wall tube.... Nice job......
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
donn0128
Thats exactly what i did. To go along with the hitch platform i added two pads for the rear stabilizers to bolt to. Has worked well for nine years. Mine was designed to bolt onto the frame using three 3/4 inch grade 5 bolts.
AllegroD
You also have more weight to the rear but you are probably already considering that.
OpenRangePullen
Becareful on what you do, you'd be surprised how easy it is to void the warranty.
2013 OpenRange Roamer 395bhs
2022 F350srw Limited, tower
2021 F150 Platinum Hybrid, daily
2002 Accord V6/5spd, project
2014 Kawasaki Concours
Old-Biscuit
Bolted to frame should be good for 300#
jasult
BB_TX wrote:
Before you hang anything off the back, follow someone that has one down the road and watch how badly they bounce, even on relatively level roads.
On stock bumper yes, I have been running for 5 years with my heavy bumper mod and 0 problems.
Jim & Georgeanne + Lucie the beagle
"excavator" on the DieselStop.Com
1999 F350 CC LB Hydra chip
1996 F250 Powerstroke, Tony tunes, BTS trans
1995 Fleetwood Wildness 30 ft 5ver
Our Camping Pics and 5ver Album here
Our Gettysburg trip 2010
Williamsburg, Va
BB_TX
jasult
I made my own heavy duty bumper and installed 3 receivers
click here
Williamsburg, Va
Ron3rd
Don't use your bumper, it will flex and crack eventually. There just thin metal. On my last trailer, we came off the frame with some angle iron and fabricated mounts.
Equilizer Hitch
Honda EU2000
