โDec-23-2018 08:52 AM
โDec-24-2018 03:06 AM
โDec-23-2018 08:26 PM
โDec-23-2018 07:11 PM
MitchF150 wrote:
What are the volts when the truck is plugged in and supposed to be charging the RV battery?
โDec-23-2018 06:52 PM
SoundGuy wrote:Chainwright wrote:
I'm thinking if your battery is 5 yrs old, it's pretty much on it's last leg. The DW and I just changed out our 4-5 yr old battery on our cars too. They gave out on us. Just be safe change your battery. JMHO.
My Silverado had an AC Delco Professional Plus battery with a 42 month, full replacement value warranty. It pooched on me just weeks after that 42 month expiry :R so I anted up for the Group 48 AGM recommended for my truck, sold by Canadian Tire with a 5 yr warranty. I'd consider 5 yrs out of any battery pretty respectable.
โDec-23-2018 06:25 PM
SoundGuy wrote:midnightsadie wrote:
its time for a new battery. anything under 12.8 is not good and its 5years old.
A fully charged flooded battery with no load on it should read in the 12.72 volt range, under load voltage will obviously drop, and the greater the load the greater the voltage drop. One can easily see voltage drop into the high 11s under heavy load but once that load is removed voltage will bounce back. Ideally you don't want to draw a flooded deep cycle battery down any more than ~ 50%, meaning it's unloaded voltage should drop no lower than ~ 12 to 12.1 volts. From the OP's description it would seem his battery is due for replacement.
โDec-23-2018 06:14 PM
โDec-23-2018 05:05 PM
โDec-23-2018 04:20 PM
โDec-23-2018 04:15 PM
โDec-23-2018 02:23 PM
jornvango wrote:
We have one 12v battery in a travel trailer. After driving for 5-6 hours on Friday, we boondocked in Texas. 40s at night, 50s during the day. We only used 1 led light in the evening and the water pump a few times. The fridge is on all the time (battery/propane).
Yesterday Saturday, in the morning when we used the water pump, it kept rattling away as if it didn't have enough power. Fridge and lights worked.
We plugged in the portable 100w solar panel. The charge controller read 9.7v! After a few hours of solar charging, it went up to 12.2v but by the time the sun set, it showed 11.57v even though nothing but the fridge was on in the camper.
This morning (Sunday), when we plugged in the solar, it read 9.7v. Water pump kept rattling away after we washed our hands and the led lights were dimmer with the pump on.
Some facts:
- flooded battery dated 2013
- type marine (it shows cranking amps on the label)
- fluid level is ok
Is the battery dead / beyond repair? How come the fridge and lights still work?
Based on my limited knowledge, a battery shouldn't be below 12.3v ... Based on the past experiences, one night of light usage after driving, the battery should still be around 12.6v...
โDec-23-2018 01:51 PM
time2roll wrote:
Not going to find a real deep cycle in these sizes at a common retail store. Need to go to a battery distributor that carries Trojan, US Battery, Rolls etc and they will be a bit more $$.
Many Costco/Sam's Club carry the 6v GC2 that is made for deep cycle at a good value (need 2).
โDec-23-2018 01:41 PM
jake2250 wrote:
Also by doing it online you won't get charged a "Core Fee", you just go in and show your receipt and your good!
โDec-23-2018 01:40 PM
โDec-23-2018 12:41 PM
โDec-23-2018 11:32 AM
