CAMCO Quickie Flush
SHRED
I had this on the black tank of the motorhome I just sold and loved it but it leaked.
This time I tested it before installing on my new motorhome.
Make sure that hose clamp is very tight or use a different hose.
Also, I most likely will use this added elbow to relieve tension on the tubing plus it will make hose replacement easier if needed in the future.
2021 27' Lazy Daze mid bath
3 REPLIES 3
SHRED
Thank you for that quick connect link. Great idea!
IAMICHABOD
I did this on my black tank 8 years ago and added the elbow as I Posted earlier and have had no leaks from the connections after I got it tight.
Also I found that another nice mod was to add a Quick Disconnect to the end to make it easier and quicker to do a Flush.I use the Quick Disconnect on all my hose connections,but only a special hose for the black tank wash.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
time2roll
Elbow is good. I used a pex to hose bib adapter to use real plumbing instead of that flimsy hose. Yes I had a couple leak and eventually blow off.
I also drilled a few extra small holes in the nozzle. Some directed at the sensors and the rest to put more water to the back wall of the tank. Do this on a warm day so getting soaked during the test is all part of the fun.
