In Search Of 12V Switch and Dimmer Control
ChooChooMan74
Just as it sounds. I found this on eBay for $42.99 :E And RV stores online wanted LOTS MORE!!! Maybe some of you have seen something similar, maybe closer to the $20 range???
Here is what I want to do. My LED upgrade in my bathroom is great, except for the night time bathroom use, I think they are too bright. I want to be able to dim them for night time use, just enough to aim at the bullseye.
2nd option would be an LED courtesy light, mounted higher than normal.
FYI, I did the whole trailer in LEDs. I replaced many of the switches on the fixtures with DPDT switches so I can use either 1 or both sides of the light. I could do that for the bathroom, but it will still be too bright.
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
14 REPLIES 14
BarneyS
2oldman wrote:
Are all 12v LEDs dimmable? 120v ones are not.
We have several of these LED bulbs in our fixtures at home and they are fully dimmable. I have seen many others that say they are also.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
ChooChooMan74
My LEDs from Home Depot in my Poloymer Products 6 Globe Awning lights are sure dimable. I use a regular in line house lamp dimmer on those. Bright for eating and cooking (DGF has vision issues), dim evening.
MrWizard
Moderator
Moderator
The 120vac LED's candlelabra bulbs in my dining room fixture are dimmable
I can explain it to you.
1997 F53 Bounder 36s
Chris_Bryant
I've been looking at This touch dimmer
Only does 3 amps though, but $14 is a winner.
-- Chris Bryant
ChooChooMan74
Thank you everyone for the suggestions sonfar. ๐Ÿ™‚
Class_A_DP_1
I did just what you are speaking of for the bathroom. I used this one... http://www.ebay.com/itm/330833060377?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I only have a few hours use on it so far but it does seem to work fine for my ebay Chinese LED's.
Prevost XL40 Country Coach Conversion
Need-A-Vacation
What about a LED "puck" light? Just enough light to see but not blinding. We use a couple for the boys to have a little light if needed, 1 near the bunks, and the other in the bathroom.
Good luck if you choose the dimmer!
Bubba J- '13 Chevy Silverado 2500HD LT CCSB 4x4 6.0
'16 Jay Flight 32 BHDS ELITE 32 BHDS Mods Reese DC HP
WDH Set Up. How a WDH Works. CAT Scale How To.
myredracer
What about this one on ebay for $19?
RV LED dimmer
GordonThree
If you bought your LEDs off ebay, chances are you can dim them, as they have no onboard regulator. If you bought LEDs from M4 or SuperBright, they have on-board regulators, and are either non dimmable, or require something special to dim them.
easiest solution might be an LED night light, the kind that plugs in. I have an outlet right above the head, so a tiny eyeball shaped LED night light plugged in there lights the bullseye as you call it, easy peasy. of course, my 120v is always powered, whether I'm plugged in or not, so your mileage may vary with this solution.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
JaxDad
I used a twin LED licence plate light, but snipped the wire between them and soldered in a third lead, 2 x positive, 1 x negative, wired to a 3 position rocker switch with LED pilot light. Center is off and switch lit, up is both LED's, down is a single LED.
The light was $6, the switch and wire was already in 'inventory.
doughere
You could put a resistor in the line that feeds the first lamp in your two position switch, first position to bulb with resistor which would be dimmed, second position to other bulb. Adding a diode from second bulb to first would bring first bulb up to full output.
Cheap and easy.
Doug
Corkey05
The Ebay control you link to is a PWM (pulse width modulation) dimmer control. It basically pulses current to the light in controlled frequency to control the amount of time the light is in an on/off cycle. Great for incandescent and halogen bulbs, but not so good for LED's
Here is a link to a wealth of 12v LED dimmer controls.
12v Dimmer Controls
You'll love the LED's ... I sure do. ๐Ÿ™‚
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
2oldman
Mandalay_Parr
I did a Google search and found several for under $20.
Maybe Lowe's or Home Depot or the such.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
